315's A/T tire pressure?
Old Nov 21, 2003 | 09:07 AM
shaft's Avatar
What's the tire pressure do you guys usually run on your 315's (not towing)? What's the max pressure can you put in these tires? Thanks.
Old Nov 21, 2003 | 07:41 PM
phox_mulder's Avatar
Re:315's A/T tire pressure?
I think the max pressure is different on the 16 and 17 inch versions.
On my 16 inch the max is 50psi.
I run 50 up front, and they still look low, and 40-45 in back and they look just right.
I tried 50 in back and they were too bouncy.
If I ever had the opportunity to tow something, I'd probably put more in the rears.
phox
Old Nov 21, 2003 | 10:19 PM
bulabula's Avatar
[quote author=shaft link=board=49;threadid=22679;start=0#msg212266 date=1069427246]
[/quote]What does it say on the sidewall?
Old Nov 25, 2003 | 10:23 AM
Geets's Avatar
Did the 315/70/17's fit without a lift? Did you have to install a leveling kit? I still have my stock tires and want to go bigger. How big can I go if I install a leveling kit?
Thanks,
Steve
Old Nov 25, 2003 | 08:16 PM
shaft's Avatar
[quote author=Geets link=board=49;threadid=22679;start=0#msg214021 date=1069777427]
Thanks,
Steve
[/quote]
Steve -
315's will fit without a lift. I did not have to use a leveling kit. It fits very nicely.
Old Nov 26, 2003 | 12:27 PM
Geets's Avatar
Shaft, Since we both have the same gears and both are 3500's what if any effect has it had on your mileage? Did you do anything about the speedometer being off? You wouldn't happen to have any pictures with the 315's on would you?
Old Nov 27, 2003 | 11:27 AM
shaft's Avatar
[quote author=Geets link=board=49;threadid=22679;start=0#msg214494 date=1069871242]
[/quote]
I'm pretty sure I'm the fuel efficiency has gone down a little due to the obvious fact that the 315's are heavier and have more road friction. I did not do anything to my speedo because it's only 5 mph slower than the actual speed of the truck.
Old Nov 27, 2003 | 11:31 AM
shaft's Avatar
another pic.
Old Nov 27, 2003 | 11:32 AM
shaft's Avatar
and another.
rjordan
Sep 27, 2004 09:25 AM
cquestad
Jun 22, 2004 12:31 PM
BamBam
Sep 25, 2003 06:03 PM
