22.5 semi wheels
Old Feb 12, 2007 | 07:54 PM
D.Wiggs's Avatar
Originally Posted by WHITE3500DUALLY
hey wiggs have you ever notice how some of the big rig wheel trucks pics from other sites end up on other big rig wheel sites galleries?
I sure have. It's like there is a "community pool" of photos that everyone posts!!
Old Feb 12, 2007 | 09:22 PM
Z06-LITE's Avatar
Hi 03sled, no I did not have to remove the fender liners. I did have to cut a small half moon section from the front fender liner toward the rear and a small triangle section from the front of the rear liner. I will get photos up soon.
Old Feb 13, 2007 | 08:54 AM
JD Dearden's Avatar
Originally Posted by RAMRODD
what do you mean by equal balanced?? Is that were they use the powder in the tires??
A few days ago I mentioned using all aluminum rims in the back. and you mentioned that they can fuse together. Well when I ordered my tires I found out their is a ring you can put between them to prevent any scuffing they were about $3.50 each any tire dealer should be able to get them!
Dwiggs you were right David at the dually stop got me a good price on my adapters!!
I have no personal exsperiance with this but everyone says you can't run two aluminums together if you could I am sure every semi would have it that to reduce weight, equal balance is the stuff they put in that is a powder that balances them while you drive.
Old Feb 13, 2007 | 09:39 AM
007MegaRam's Avatar
The equal your are refering to, There are several products for that out on the market. I just had my RV (Prevost Coach) Tires replaceded and when I get home I'll see what the balancing compond they used was. The guy who I talked to said there are only a few you want to use because the moister in the air will cause some of the powders to glob and that just turns into a mess.
Old Feb 13, 2007 | 01:36 PM
D.Wiggs's Avatar
You can run two aliminums together; you just need the rings inbetween. A lot of Semi's do run all aluminum to save about 25lbs. per wheel. The reason why they don't is the cost is not worth the insane price increase and also, Supersingles will save you more than 1200 lbs.
Old Feb 13, 2007 | 01:55 PM
JD Dearden's Avatar
Huh everyone I spoke to said that there was nothing out there to prevent the forging when I was purchasing mine.
Old Feb 13, 2007 | 02:08 PM
D.Wiggs's Avatar
There is something available because I cannot tell you how many Kenworths I have bene looking at run 10 Aluminum wheels. I think someone even posted in this thread or one similar that the rings are like $4.00!
Old Feb 13, 2007 | 02:09 PM
JD Dearden's Avatar
Ya I saw that I haven't ever seen all aluminum on a semi, but haven't looked that hard either.
Old Feb 13, 2007 | 02:20 PM
D.Wiggs's Avatar
I only know because I have been searching for one; but you're right, unless you look up close, you would never know.
Old Feb 13, 2007 | 07:41 PM
Z06-LITE's Avatar
A little off topic, but the two new steel inner rear wheels for my truck arrived today by UPS. I was really suprised when the shipping label for each wheel listed the weight at 83 pounds. I had no idea they were that heavy.
Old Feb 13, 2007 | 07:56 PM
D.Wiggs's Avatar
Yeah, the steels are 83 and the aluminum are 60.
Old Feb 13, 2007 | 08:46 PM
RAMRODD's Avatar
The box weight that my rims were shipped in were 55 pounds.
I heard that antiseize will work between aluminum rims to.
Still looking for rear fender flares
Old Feb 13, 2007 | 08:47 PM
D.Wiggs's Avatar
What's wrong with the Xenon ones or Bushwacker?
Old Feb 13, 2007 | 09:13 PM
RAMRODD's Avatar
Where is a good place to get them. I went to a truck accesory store today and they said nobody makes the fender flares for a dually I even asked about Bushwacker!
Old Feb 13, 2007 | 11:26 PM
D.Wiggs's Avatar
They definitely do! If I am not mistaken, when you have the standard 8' bed, you just use the standard rear flare on the dually "buldge". That's what I have always seen and I love the way it looks. You could get them from Stylin Concpets I am sure. It won't say that it is for teh dually, but it works just the same!
90 damram
Oct 16, 2013 05:34 PM
440_D50
Feb 10, 2010 01:00 PM
hardheaded
Mar 7, 2008 12:26 AM
yfz450guy
Feb 9, 2007 08:32 PM
