2004 Dodge 2500 4.56 gear swap questions
Old Sep 17, 2008 | 09:25 PM
dodge35000's Avatar
I will be replacing my 3.73 gears and installing 4.56 gears in my 9.25 AAM front axle and in my 11.5 AAM rear axle.
I had a few questions for anyone who has done this swap:
First, did you have any problems taking anything apart(ie. removing pinion yoke etc.) or putting it back together?
Second, did the pinion depth come out correctly with the factory pinion shim?
Third, how many tries did it take before you achieved an acceptable pattern?
Lastly, any tips that you may have?
Thank you in advance.
Old Sep 17, 2008 | 10:20 PM
gus's 03's Avatar
the yoke is a verry tight press fit onto the pinion shaft
best tip i have is verifying if your getting 2 step or 5 step gears, patterns and setup specs are totaly diferent.
if the guy your getting them from doesnt know, then buy some where else or make sure you can tell .....
Old Sep 18, 2008 | 10:08 AM
AH64ID's Avatar
What size tires are you running to warrant 4.56?
spoolinup
Jan 8, 2010 06:25 PM
Hetdiesel
May 23, 2009 07:40 PM
dodge35000
Sep 19, 2008 06:20 PM
joebishop23
Oct 29, 2007 10:19 AM
leadpants
Oct 9, 2005 01:44 PM
