2004 Dodge 2500 4.56 gear swap questions
I will be replacing my 3.73 gears and installing 4.56 gears in my 9.25 AAM front axle and in my 11.5 AAM rear axle.
I had a few questions for anyone who has done this swap:
First, did you have any problems taking anything apart(ie. removing pinion yoke etc.) or putting it back together?
Second, did the pinion depth come out correctly with the factory pinion shim?
Third, how many tries did it take before you achieved an acceptable pattern?
Lastly, any tips that you may have?
Thank you in advance.
It will be be closer to stock , but with the power these trucks make ,it`s not necessary.....plus your HWY rpms will be screaming.
I had to run my stock wheels/tires recently , and hated the higher rpms the truck was running.
spoolinup
Jan 8, 2010 06:25 PM
Hetdiesel
May 23, 2009 07:40 PM
dodge35000
Sep 18, 2008 10:08 AM
joebishop23
Oct 29, 2007 10:19 AM
