'08 Wiring Help
'08 Wiring Help
Hey guys: I'm installing a back-up camera and need to know what color the wires are for the reverse lights on an '08 3500 4X4. Any help or a point to a wiring diagram would be much appreciated.
TIA.
TIA.
you might just need to get in there and see which wire it is hooked up to them.
I don't know but, I kinda doubt a diagram is out yet for your truck. I know it took almost till summer last year for the diagram to come out for the 07's. Those truck started selling in late 06.
Good timing on this as I'm doing the same thing! You tapped in right by the brake light so I take it the camera unit itself controls when the signal is sent to whatever kind of monitor you're using? I have an in-dash Alpine DVD head unit and the reverse wire needs to be run to it as opposed to the camera itself. When I'm in reverse the screen simply switches to the reverse camera input.
Any ideas for how I would tap into the brake light closer in to the cab?? I could always follow the brake light wire that you describe as far towards the cab as possible and splice it there but I would think there's a better way.
The camera to monitor link on mine is wireless. I turn on the monitor (the monitor can be plugged into a 12V receptacle or hard-wired - it comes with both harnasses) in the cab after I start the truck and when the truck is placed in reverse, the camera is powered via the wire where I tapped into the reverse light. Once the camera is powered it sends the video to the monitor and I see the image in the cab. If you put the truck in Reverse with the engine off but the key on and all of the other lights off you should be able to identify the reverse light wires in the harnass with a volt meter. Like I said, the left reverse light on my '08 was green/white (positive) and the negative was the solid black.
Good luck.
wyododge
Jan 13, 2009 02:25 AM
charcoal600
Apr 30, 2005 02:34 PM
Hummin Cummins
Mar 24, 2003 07:41 AM
