03 turbo swap
03 turbo swap
Is it possable to switch out the stock turbo on the 03-04 with the later 04.5 up models? I know the later ones used electronic wast gates but could you take that off and and just use a mechanical one like the earlier models used? I thought I read about doing this on here and I cant find it Thanks for the help
Matt
Matt
03-04 stock turbo 54mm 455 HP Max
04.5+ stock turbo 60mm. 520 HP Max
Only thing required is a different exhaust elbow as the 03/04 are 3.5" and 04.5+ are 4".
No need to touch the wastegate, it works fine as is without modification for 26-28 psi. If you want big boost and power, splice in a boost elbow, wastegate controller, pinch the line with vice grips, or disconnect from wastegate head and plug the silicone line with plug/screw and hose clamp.
The electronic component is simply an electric bleeder valve. When energized it bleeds boosted air out of the silicone tube to prevent boost pressure from filling the wastegate head/extending rod/ opening internal exhaust bypass puck.
Stock 04.5+ trucks activate the electronic solenoid for a few seconds to allow boost to spike to 31-32 psi and then turn off allowing full boost to work on the wastegate head and fully open the exhaust bypass puck.
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
