03 mod ?s
ok so changeing the intake will make diff or ?
and is 04.5 turbo bigger and duh better whats so good bout it
where do u buy smarty how much
thanks for all help to
You can get the Smarty from the DTR store. "Shop DTR" at the top of the page. Larry will take care of you. As stated the turbo has bigger impeller and housing ,flows more air and usually decent priced when you run across them. Intakes help no doubt, but for a stock truck, the money could be better spent elsewhere.
need a plug for where the electronic actuator goes. Tap that plug for 1/8NPT, install a boost elbow and hook up the hose to the actuator. The cast elbow on the turbo will either require using a later model downpipe (recommended) or you have to swap the elbow off of your current turbo.
Kenworth
07-15-2008 04:18 PM
jmccart
12-19-2007 12:49 AM
jamesbfishin
07-07-2007 08:25 PM
wap
14
04-23-2007 06:46 PM
RAMV
07-14-2004 12:08 PM
