wont shift into 4x4
Old Jan 14, 2011 | 10:34 PM
kingofdodge7131's Avatar
wont shift into 4x4
Hey guys. Anyone had the electronic 4x4 transfer case apart? It was only shifting when I was stopped now the indicator only blinks. If I'm sitting still I can hear the slide sliding. How are the forks attached? Any ideas on the cause?
Old Jan 14, 2011 | 11:04 PM
Ms. Diesel's Avatar
Will it shift into 4x4 with the truck rolling slowly?
Old Jan 15, 2011 | 12:02 AM
Use too. Up to say 5 mph or so. Now its not doing anything
Old Jan 15, 2011 | 12:05 AM
And. We are talking about 4hi or 4 lock as its labled. Not 4 low
Old Jan 15, 2011 | 11:48 AM
anyone have these problems?
http://www.carcomplaints.com/Dodge/R...el_drive.shtml
Old Jan 15, 2011 | 05:46 PM
Ms. Diesel's Avatar
Took a peek at mine today and 4 hi engages really quick. (like 1 second, slight clunk) going into 4 low takes a few seconds. Does it continue to flash after it tries to shift?
Old Jan 16, 2011 | 12:17 AM
If I'm going under 7 or so it. Will shift wuithin firsr 5 flashes. Anything over 10 mph and no shift. Per owners manual and a 2004 service manual I'm meeting all the user controllerable variables. Hence my frusteration. Dealker says there is no programing that can change it. Seems to be something that they sgould be able to tell me. Sorry for typos. Stupid blAckberry
Old Jan 16, 2011 | 01:36 PM
Also won't shift out till same speed is met
Old Jan 18, 2011 | 10:33 PM
Uopdate. So when I shift it sounds like a manual shifting and grinding gears. Whhat would cause that?
Old Jan 19, 2011 | 05:39 PM
SpeedyWS6's Avatar
Worn tires can cause a difference in ratio that can result in binding of the 4 wheel drive components.
Billwie
Oct 4, 2008 03:07 PM
A_Manke
Feb 12, 2008 11:08 PM
shorte_33
Jan 18, 2008 12:32 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
powerwagon440
Jan 31, 2003 01:10 AM
