will it do the job
Old Nov 20, 2011 | 03:49 PM
mag2ram's Avatar
will it do the job
ok guys Im looking at a mega cab 2007 drw 2wd with 33k on the dash. I know the cab is huge and I just need to know will the cab be in the way for a three car hauler?
Old Nov 20, 2011 | 10:38 PM
rich's Avatar
you have to be careful on the turns depending how the neck is set up. best thing to do is to take it and see.
Old Dec 15, 2011 | 09:44 AM
rdut's Avatar
If the trailer can work with a short bed truck you should be fine
Old Dec 30, 2011 | 04:05 PM
Jesse465's Avatar
do u have a gooseneck hitch? if so b&w makes a drop in ball that is offset by 4 inches to make it work correctly....When I buy my hitch I will be getting the offset ball
Old Dec 30, 2011 | 08:31 PM
Blake Clark's Avatar
One of the main reasons I got my Crew Cab Long Bed. It can be done with the mega and short bed, but you will have to be diligent and prepare for and watch every single turn.
Old Dec 31, 2011 | 08:50 AM
Jim W's Avatar
I have towed two different 5er's with my Mega Cab. Both have had extended pin boxes installed on them and I use a slider hitch also. The only time I engage the slider is when I back up into my drive way and when we are in the campgrounds. When I am towing the 5er on city streets and the highway I do not need to engage the slider hitch. There is enough clearance to make the turns with the 5er in the towed position.
Another option that will work if you are concerned is a pullright hitch. These automatically slide back as you maneuver without you having to disengaging the locking lever.
See attach link: http://www.pullrite.com/
Jim W.
Old Jan 27, 2012 | 06:25 PM
clarson80's Avatar
I wouldn't worry about a short box if it's a gooseneck trailer. You have to turn very sharp to have an issue. I really don't notice more issues when I pull my goosneck with my shortbox compared to my longbox. Backing up and turning VERY sharp, I could see an issue.
AKDSLDOG
Mar 14, 2003 10:19 PM
shortfieldbreak
Dec 2, 2002 09:12 PM
Scotty
41
Nov 11, 2002 11:15 AM
Nov 4, 2002 12:03 PM
BIG&BAD
Oct 14, 2002 02:42 PM
