voltage jumping up and down
Old Dec 21, 2007 | 06:57 PM
TG01's Avatar
My voltage on my 07 3500 4x4 6.7 is jumping from 8 t0 16 amps. I drove about 75 miles at night it looked like i was flashing my lights from bright to dim for an hour or so I took to the dealer and they said they cant duplicate the problem " who'd a thunk it" it does it all the time now. figured id wait till whatever totaly broke so the dealear coul find the problem....anyone else had this issue.
Old Dec 21, 2007 | 07:06 PM
P.J's Avatar
P.J
Sounds like the grid heater cycling. Where are you located?
Did you allow the truck to warm up a few minutes before taking off?
Old Dec 21, 2007 | 07:09 PM
82NDSNPR's Avatar
its the grid heater man mine does the same thing once i moved to wi and it was cold enough once the motor starts to get cold she will cycle the grid heater on mine wont do it im going down the road but at start up she will and if she sits and runs long enoough where she cools down she will do it
Old Dec 21, 2007 | 07:14 PM
P.J's Avatar
P.J
HIGH IDLE.
You guys should consider running it up to around a grand to help with this "problem"
Old Dec 21, 2007 | 10:16 PM
TG01's Avatar
I live in New Mexico. It was happining early fall when it was in the mid 60's but it is doing it more now that it is the mid 30's. I figure a 70 mile drive would be enough to warm pretty much everything up.
Old Dec 21, 2007 | 10:24 PM
graphitecumnz's Avatar
If it's the grid heaters, they are malfunctioning.
Old Dec 21, 2007 | 11:16 PM
82NDSNPR's Avatar
the grid heaters will do this dodge does have a reflash for the system that is supposed to ensure this only happens when the truck needs it. i got mine reflashed and it does it alot less now but its still -10 and below here. also your truck will also go into the high idle if its under 25 outside it will automaticly run up to 1k rpm so PJ my tuck does that on its own for me
Old Dec 21, 2007 | 11:42 PM
TG01's Avatar
my high idle does not turn on automaticaly. I have to do it manualy. Guess I better take it back in......Thanks Guys.
Old Dec 22, 2007 | 02:26 AM
DaveB.inVa's Avatar
It sounds like the grid heaters cycling. Your volt meter will drop from around 14 to 8 or so volts like you say but it should stop it after you get over about 18~20 mph.
AlexDring
Dec 29, 2010 07:20 PM
NE frmhnd
Nov 9, 2010 06:41 PM
vegburner
Nov 11, 2007 07:37 PM
360ramcharger
Nov 15, 2004 06:08 PM
doomgaze
Oct 23, 2003 04:59 PM
