voltage keeps jumping 10v to 14.5
Old Nov 15, 2004 | 08:44 AM
360ramcharger's Avatar
last night I started my truck 44deg air temp and the volt meter stayed at about ten volts, about 2 minutes later it went to normal
14.5 Approx. then it drops back down to ten the light went dim
and then back to normal. it did it again this morning, whenever I start the truck it does this for a minute or two the stops. back and forth it does this and then stops. altenator or a grid heater problem. I wouldnt think the grid heaters would pull that much power.
Thanks,
Mike
Old Nov 15, 2004 | 08:46 AM
SHARPMACHINE's Avatar
It is the grid heaters, my truck does the same thing..
Old Nov 15, 2004 | 09:19 AM
is this normal ? this is my first winter with a diesel, Im not used to the Cummins engine I bought this truck 4 months ago so Im still learning. any input would be a help, when the lights go dim and the voltage drops that makes me worry
thanks!!
Old Nov 15, 2004 | 09:25 AM
I PASS GAS's Avatar
Take a look at the gauge wire going to the grid heater, you will then understand why your lights are dimming and your voltage is dropping. They use lots of juice. What you are seeing is normal.
You can now sleep at night.
RustyJC's Avatar
Yes, it's normal. This is another reason your truck has two batteries.
Rusty
Old Nov 15, 2004 | 09:32 AM
Great!! thanks yall, I thought I needed a new altenator,
I didnt think of the grid heaters until yalls replies then I did a search and found that question has been asked alot. thanks for taking the time to help.
Mike
Old Nov 15, 2004 | 02:32 PM
jrs_dodge_diesel's Avatar
When it gets cold enough the grids cycle to help warm up the engine. There are 2 grid heaters, one on top the other. Each heater draws approx 90 AMPS. quite a hefty load. If it gets cold where you live I reccomend using your block heater.
Old Nov 15, 2004 | 02:36 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Now that you know the 'secret', it will be your turn to jump in and help all the other first time diesel owners who post of this cold starting phenomenon until the weather warms back up.
Old Nov 15, 2004 | 05:40 PM
INJECTOR JACK's Avatar
Yep normal. You probaly had your heater on full and your headlights on this adds more voltage drop. Your batteries may be a bit tired as well.
Old Nov 15, 2004 | 06:08 PM
phox_mulder's Avatar
Then what would us moderators do?
I live for the brisk fall weather and the Diesel noobs.
phox
imbodie
21
Jan 8, 2024 08:49 AM
NE frmhnd
Nov 9, 2010 06:41 PM
victurner
Dec 27, 2008 03:12 PM
TG01
Dec 22, 2007 02:26 AM
vegburner
Nov 11, 2007 07:37 PM
