ULSD vs LSD
Old Dec 8, 2007 | 04:44 AM
White Fury's Avatar
ULSD vs LSD
I was in the middle of nowhere and had to fill up with LSD. Will this hurt the 6.7 or is it ok as long as I run ULSD on my next tank?
Old Dec 8, 2007 | 06:23 AM
sabersix's Avatar
I used about 10 gallons of LSD once to get the the next ULSD station. If I was you, I'd start mixing in ULSD at around 3/4 tank and keep doing it 3-4 times.
Don't worry too much though, LSD is required to be a maximum of 500 ppm, but does not have a minimum so you may have gotten ULSD type levels of sulfur. Some stations get ULSD and never change the sticker.
Old Dec 8, 2007 | 07:35 AM
ccoop769's Avatar
Ive filled up with LSD about 100 gallons at once. Wont hurt the truck.
IT will go into regen alot more and waste more gas and feel like a dawg from the regen since the regen will take longer and more of them to burn it off. Never threw a light or catilysit message.
Old Dec 8, 2007 | 08:33 AM
White Fury's Avatar
ok ULSD it is next time. I don't think I saw less than 14 mpg and most of the way it was up to 19mpg. Drove about 275 miles on it so. How often will it go into regen mode?Should I mix anything i..e... Additives to the fuel.
Old Dec 8, 2007 | 09:42 AM
MikeyB's Avatar
In a emergency situation LSD is ok.
MikeyB
Old Dec 10, 2007 | 09:54 AM
KMKDiesel's Avatar
I have seen ulsd screw up more 5.9s then lsd screw up 6.7s. I know alot of people that have lost there injectors from the ulsd.
Old Dec 10, 2007 | 11:30 AM
Scotty's Avatar
Top's Younger Twin
By mistake on my first work trip with the truck I filled the factory tank with LSD.
Never made a difference in the regen on the truck. However, it netted the best mileage I have had. 17 and a bit on the highway. I had already used the LSD when it came time to hook up a load so no mpg for towing.
Scotty
Old Dec 10, 2007 | 02:25 PM
KMKDiesel's Avatar
I have used lsd for 90% of the miles on my truck and the only problems it gave me was better milage and power.
woodperson
Sep 17, 2007 01:09 PM
garymcbroom
16
Jun 18, 2007 12:31 PM
mike moore
20
Jun 3, 2007 07:06 PM
amartinson
Dec 10, 2004 04:04 PM
