Trans temp fitting
Old Mar 20, 2010 | 10:24 PM
2171CTD's Avatar
Question Trans temp fitting
I ordered my Isspros, trans temp, EGT and boost. I also got the T fitting for the trans sender. http://www.glacierdieselpower.com/pr...pf_id=500-TTSA Has anyone used this on a 68rfe? GDP says to cut the line and put the T in place. Never had to cut a trans line before. I have a mini hacksaw and a Dremel that I can use, or should I hit up Harbor Freight for some tools?
Old Mar 21, 2010 | 06:47 AM
Blake Clark's Avatar
Not familiar sorry.
But do a good write up with pics. This is something I intend to get around to one day.
Old Mar 21, 2010 | 09:06 AM
Jim W's Avatar
Remember once the line is cut the trans fluid will run out from both ends. You will need to refill the trans with the proper fluid, so make sure you have some on hand.
I instead put a Mag-Hytec pan on, then put the trans temperature probe gage in the pan. This way I could return the truck to stock, if I sold the truck. The new pan also provides for more cooling through the AL pan and more capacity. When I tow my 5er I am usually around 180F in the summer on flat land with this configuration.
If you decide to go this way I would change both filters and put new trans fluid in.
Just my $0.02
Jim
Old Mar 21, 2010 | 04:21 PM
2171CTD's Avatar
I was going to go the pan route, but spent the funds on a wastegate instead. Ill do a write-up for ya Blake.
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
dieselfuelonly
Jul 25, 2007 06:30 AM
upersleder
Mar 9, 2007 08:47 AM
ckennedy
Nov 10, 2004 01:03 PM
