tanny slips after setting all nigh
2007 Dodge Ram 2500 4x4 6.7 L. I recently change my transmission oil and both filters replaced them with Mopar filters an +4 mopar oil. after trans. sets for a long period usually over night. the trans is slow to go in gear. droped pan to make sure that no o-rings were left and the the bolt on filter gasket was setted properly. I installed the small o-ring first and then the filter and it was seated properly.
The 68RFE will not lock the converter up or go into 6th gear until it sees a certain trans temp. When it's colder outside it'll take longer to lockup. This is totally normal
He's not talking about lock up. He's talking about intial get into gear and get yer a$$ moving. Mines been in the dealer for this also. They can't fix it. Last time they wanted to pull the trans out of it. I declined.
The tell tale sign is to pull the dipstick after it's sat a while. The trans fluid will be every bit of 2" high on the dip stick. All the fluid is draining out of the cooler back to the pan. The check valve isn't working correctly.
The dealer changed mine out, but after a thousand miles or more it's doing it again. So no hope for a true fix. It's completely normal.
jhpate
17
May 30, 2008 07:08 PM
12valve
Apr 27, 2007 10:20 AM
guzzirider
19
Jul 20, 2004 04:53 PM
