Stacks with dpf
Old Dec 16, 2007 | 09:31 PM
KMKDiesel's Avatar
Stacks with dpf
Anyone put stack on there 6.7 yet with the dpf. I was thinking just putting in a t and a valve so I can run stacks while sled pullin and for fun, but still have the stock exhaust also. I think a few people have this set up on there 5.9s. I know JD does he gave me the idea from seeing his truck.
Old Dec 17, 2007 | 12:14 PM
Duallydog's Avatar
I've done similar, go to http://buickgn.com/electricexhaustcutout.htm that's where I got my cutout. I have it on a Y pipe just before the muffler, and its just venting under my truck for now.
Old Dec 23, 2007 | 11:09 AM
SpinEmNSmokeEm's Avatar
I just got a glimpse of the new 8 LUG magazine and it had a C&C I believe with a lift and 22.5 's or something and they were putting on an MBRP set of stacks. I didn't get to read much because the wife was tugging at my coat to go. Hope that helps you out.
Old Dec 23, 2007 | 03:50 PM
Little03's Avatar
Yes I read that issue, they just used a Y pipe off the DpF, Anything is possable just some imagination and you can do it.
Nick.
Old Dec 23, 2007 | 04:25 PM
Steven K's Avatar
You would have to put your T valve after the DPF. Others that have tried running without a DPF and found their ECM de-rated the engine output. If you stop running exhaust through the sensors for the emmisions system the computer will de-rate the engine.
fishnfreak86
Jun 11, 2014 08:44 AM
rip 112
16
Jan 15, 2010 02:46 AM
DarkDesertCTD
Mar 9, 2009 01:08 AM
CHOPPER ROB
Jan 18, 2009 07:11 PM
