Silencer ring on 6.7
Old Jun 26, 2007 | 08:16 AM
proworks1's Avatar
I ordered the parts to make my cold air intake on my 6.7 and I was wanting to know if there is anyone out there that has removed their silencer ring yet, If so could you let me know how to remove it.. Thanks in advance for any info.
Old Jun 26, 2007 | 09:51 AM
rstone's Avatar
no I don't think no one has figure it out yet
Old Jun 26, 2007 | 04:55 PM
jtalaiver's Avatar
i need to figure it out for everyone once my truck gets here the end of this week...
Old Jun 27, 2007 | 02:25 PM
79warlock's Avatar
Warranty on the turbocharger is void if the silencer ring is removed.
Old Jul 1, 2007 | 05:24 PM
yoshimura's Avatar
Take the air intake hose off the turbo and you'll see the silencer inside the turbo held in by a snap ring, remove the snap ring and the silencer falls out. Be careful not to scratch the inside of the turbo up and pay attention to where the paint marks are so you can put it back if it needs servicing.
Old Jul 1, 2007 | 06:31 PM
rstone's Avatar
well yoshimura it not that easy on the 6.7 they don't have the snap ring like 5.9
Old Jul 1, 2007 | 11:30 PM
woodsman's Avatar
What is the purpose of the silencer ring?
Old Jul 2, 2007 | 07:12 AM
MikeyB's Avatar
For reducing the audible turbine whine by smoothing out the airflow into the turbine inlet.
MikeyB
Old Jul 3, 2007 | 05:56 AM
jtalaiver's Avatar
well talked to my engineer brother and he said the joker looks like its press fit in there... which unfortunately means that it requires some SERIOUS pressure to pull it out and even pressure as well... the usual screwdriver and torque are sufficient... (believe me I know)... I am working on trying to fab a spreader that would work off of some bolts in the middle and some round flange like peices on the sides that will insert and spread as the bolts are turned... i dunno work in progress... we will see...
Old Jul 3, 2007 | 07:26 PM
yoshimura's Avatar
SNAP RING holds the silencer in !!!! I know for a fact on the 2001, 2005, and the 2007's, other than those year models i'm not sure......
Old Jul 3, 2007 | 07:38 PM
Unit44's Avatar
Question
Yea but are you talkin bout the 6.7 ?? the 5.9 was in the 2007 year also I think till May or June???
Old Jul 4, 2007 | 12:37 AM
jtalaiver's Avatar
yea man... the snap ring was for the 5.9L turbos... the 6.7L is def a different one with a press fit silencer ring and not the easily removed snap ring...
and yes... 5.9L were made up till May... so yea there are some 2007 with snap ring for the silencer but for the 6.7L its still a mystery...
Old Jul 4, 2007 | 11:11 AM
yoshimura's Avatar
My company truck is an oddball then, it has a 6.7L and a snap ring holding the silencer in, maybe it's a between model or something i don't know.
Old Jul 5, 2007 | 07:29 AM
jtalaiver's Avatar
maybe...
yoshimura any chance we could get some pictures of what you had going on there with ur Holset?
b166er [at] gmail [dot] com
Old Jul 6, 2007 | 06:54 PM
yoshimura's Avatar
I can but it's the same as my 01 and 05, snap ring then silencer.
