side wall strenght
Old Feb 6, 2008 | 10:17 PM
TheMighty'67's Avatar
side wall strenght
Im about to buy some BFG mud-terrain ta/km2's, they are for the truck in my sig. I was wondering it the 3000lbs of load range on the 35's will be sufficiant for me. I rarely ever tow, just wondering if i will get at least 40,000 miles
thanks,
Dayton
Old Feb 7, 2008 | 08:02 AM
ron b's Avatar
Toyo makes a 10 ply in 35 mud terrain.
http://marktg.toyotires.com/file/18136.pdf
Old Feb 7, 2008 | 02:06 PM
DBLR's Avatar
All I can say is what every tire you buy make sure its not a 2 ply side wall I was that they made one and would put it on 3/4 ton truck. I then saw 3 ply side wall tire and was told well the 3 plys are better then the 4 plys were a few year a go
Old Feb 11, 2008 | 12:16 PM
Fishaholic's Avatar
I don't know how many miles you could expect on the km2's. On the standard mt's you can expect good mileage. I put them on my friends 1 ton and he took them off with 85000 and still had 20% remaining. That is an exception though, but they do get good mileage. I don't believe you would see anything near that on the km2's.
Old Feb 11, 2008 | 06:04 PM
snoyes's Avatar
Are they D rated or E rated? If so, and you do not tow much, then you are fine.
If you tow more, I would lean towards the E rating. Yes, I know the weight ratings are the same, however, sidewall flex on an E rated tire are less than on a D. Less flex equals safer towing, less heat generation in the tire.
MossyOakGlock
Nov 22, 2007 08:50 AM
buddy26
34
Jan 11, 2007 12:33 PM
bensdad_canada
Sep 6, 2005 10:41 PM
davelinde
Mar 1, 2004 05:28 PM
Tackdriver
Mar 8, 2003 09:49 AM
