"see dealer now" no codes
I am getting a message in the over-head console digital display.
Service Required
See Dealer Now
i have a code reader and there are no codes shown. Is this something major? I haven't had the truck long enough to know.
07 cab and chassis 6.7. EGR stuff removed by PO, Smarty box on it.
thanks
jeff
Service Required
See Dealer Now
thanks
jeff
It is most likely for oil change. Mine is on right now. Hopefully I will get time to change this weekend. After you change oil turn key just before it starts and pump gas pedal 3 time and that will clear the message.
crank case filter was changed at 60xxx ish miles. i have 94000. dealer says it is a reset on their end, and that just resetting the truck with the brake/gas pedal may not keep it cleared.
but running a programmer, he said it may continue to come back. I don't want to spend $94 and have the same warning keep coming back. He also said it isn't hurting the truck to keep driving it either. The Crank Case Filter doesn't have a sensor on it, it is simply a mileage reminder.
i also have to plug in the smarty and go back to stock, then do the reset, then go back to a program. With no EGR stuff, i can't leave it on stock.
If you want to clear codes, all you have to do is hook up the smarty, and to the DTC code routine of reading codes.. It will may say no codes stored, just select clear codes and you are good to go. No need to reload the software every time.
I would reset the available timers per the procedure and see if that makes it go away. Also the latest version of the ME software is supposed to help out with some wayward codes.
I tried the clearing codes on the smarty, but there is no engine light on, so i guess the smarty doesn't see what is happening. the warning I am getting is in the console above the rear view. smarty says no codes thrown.
is the newer software available from smarty as a download or do you have to send the unit back? i got the box with the truck so I'm not sure how it all works.
jeff
jeff
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
jeff
jeff
There is a firmware update for the Smarty that will resolve this. It isn't noted in the change logs, but I saw a user post that updating resolved this issue.
Using the Smarty and doing the clear code procedure will also remove the warning, even though there are no codes present.
ben
ben
JS/08Ram3500
08-22-2012 07:33 PM
Polaraco
06-01-2011 12:16 AM
