Revelco or Dodge?
Old Oct 6, 2008 | 06:52 AM
Newblue's Avatar
Revelco or Dodge?
I have been having issues with the starter on my truck. After I would run the truck in warmer temperatures and shut the truck off for about 20 minutes then try to restart, it would not crank. I would then turn the key off and try it again and it would start up just fine. It has a Revelco setup on it that cuts the starter out but I don't know if that's what is doing it or the truck itself. I'm betting that Dodge will blame Revelco and vice versa. I am also getting no fault codes when this happens. I tried using the second Revlco plug and replacing the battery on the key.
2007.5 6.7 dually
stick
11,500 miles
Thanks,
Mike
Old Oct 6, 2008 | 10:12 PM
cbrahs's Avatar
Mike, contact the installer of the ravelco. I have installed a ton of them on the newer dodge trucks without a single issue. not saying that there may not be a loose connection but I would get ahold of the individual who installed the Ravelco. if you have any questions, feel free to contact me
Old Oct 7, 2008 | 07:32 AM
Newblue's Avatar
Thanks,
I'll contact the installer to see what they say. Unfortunately The installer is about 200 miles away. I am South of Indianapolis, IN and they are in Toledo, OH. It is wierd though, it always turns over on the second try when it acts up.
Mike
Old Oct 11, 2008 | 03:35 PM
nelrod's Avatar
Cbrahs, I have a Ravelco, on my 06, but it does not cut the starter out as Newblue says his does. It turns starter over without plug in, just won't start engine. Is it because his is 6.7 and I have a 5.9?
Old Oct 11, 2008 | 04:10 PM
cbrahs's Avatar
no, it is supposed to cut starter as well. who installed yours?
Old Oct 12, 2008 | 08:19 PM
nelrod's Avatar
Brett, from Raleigh NC
Old Oct 12, 2008 | 08:46 PM
cbrahs's Avatar
I talked to him yesterday about it. Call me if you have any questions. I have a couple ideas but need more info from you. did I pm you my phone number?
1stgenatheart
Oct 19, 2009 06:33 AM
joebishop23
Oct 29, 2007 10:19 AM
wreedCTD
27
Sep 30, 2007 09:52 PM
96_12V
Jul 17, 2007 07:03 PM
texasredrider
30
Nov 14, 2004 10:35 PM
