Resetting the enging oil change code?
Old Dec 27, 2008 | 11:39 PM
casimer76522's Avatar
is there an easy way to do this or is a scanner required?
Thanks Guys!
Old Dec 28, 2008 | 12:44 AM
Onelongshot's Avatar
From: Columbia in the Communist State of Chicago (Illinois)
reset it this way
I just reset mine today. Turn the key on, but don't start. Within 10 seconds of turning the key on slowly depress the gas pedal three times then turn the key off. It reset mine on the first try.
Old Dec 28, 2008 | 01:25 AM
thanks a bunch man......
Old Dec 28, 2008 | 07:41 AM
ReCurve's Avatar
Thank you I hope this works for me as well.
I got a little over 19000 miles on my truck and am on my 5th or 6th oil change. I just get tired of the oil change message, so I take her in to the dealer.
Old Dec 28, 2008 | 07:52 AM
coolbreeze's Avatar
A lot of information in the owner's manual
Old Dec 28, 2008 | 10:12 AM
J BODY's Avatar
So before you continually "reset" the oil change required, ever give it any thought as to WHY it is coming on?
Old Dec 28, 2008 | 11:13 AM
this is why
I would bet that it is because I change my oil every 5000 miles instead of the 7500 that cummins and dodge says that I can go. So every third oil change it is about right on the money.
Old Dec 28, 2008 | 11:52 AM
38short's Avatar
If your "oil change required' message comes on , let say every 3500 or so miles, is it an indicator of a fuel dilution problem. Is the over full level on the dipstick an indication of a problem .
Old Dec 28, 2008 | 12:00 PM
why read a book when you can play online!!!
Old Dec 29, 2008 | 12:42 AM
whiteeye42's Avatar
the oil change message came on in my truck which is an 08 at 3600 miles the oil level was right on went to the dealer and they said it was because the factory put in the wrong mileage in the ecm and the new flash would fix it so it would not come to early.
Old Dec 29, 2008 | 04:05 PM
dj88382000's Avatar
LOL IS THAT WHAT THEY TOLD YOU? the oil quality is used to determine oil change intervals. the engine oil condition measurement is based on the dielectric properties of the oil. as engine oil breaks down and additives are depleted, the dielectric properties gradually increase. the oil qaulity sensor determines the dielectrec constant number of the oil in a scale from 1 to 6 . SO WHAT IM SAYING HERE IS THE ECM IS TELLING YOU WHEN TO CHANGE YOUR OIL. DEPENDING ON HOW THE TRUCK IS DRIVIN OR THE CONDITION THE TRUCK IS DRIVEN IN.
Old Dec 29, 2008 | 04:29 PM
Jim W's Avatar
I believe that on the 6.7L engines with the EGR plugged in and local driving with very little highway driving the service engine soon message will be displayed more often then highway driving alone. Such as oil change is required. I believe this is due to the soot build-up with the exhaust being recycling into the engine with the EGR plugged in. My oil change light would be enable every 3500 miles or so. I am waiting to see what will happen with the EGR un-plugged and how often the message will be displayed.
My $0.02
Old Dec 29, 2008 | 04:55 PM
jerry007's Avatar
I had my oil changed at 1500 miles.I drove it about 1600 miles and the change oil signal popped up again. It seems to do this nabout 1600 - 2500 miles.
Old Dec 31, 2008 | 01:51 PM
JTS131's Avatar
jerry007;
try using amsoil and filters. my change oil light only comes on between 6000 and 7000 miles now. and the dodge dealer here in fla. recommends amsoil products. i just buy it somewhere else for much less and change it myself.
Old Dec 31, 2008 | 02:43 PM
BroncoHound's Avatar
Wrong. Show me this sensor you are speaking of. My "oil change required" message has come on within 100 miles of getting an oil change before. So my Amsoil full group IV synthetic is fully breaking down and these "oil quality sensors" you are speaking of detect that after 100 miles? Im not buying what you're selling.
My "oil change required" message has come on at 7500 miles, 15000 miles, 22500 miles, 30000 miles, and 37500 miles within ~50 miles or so each time. Some of these intervals have been nearly all unloaded highway miles, some have been idling for hours and hours, some have been loaded with 20000lbs. behind the truck. It doesn't matter how I drive or the loads I pull, the message comes on around every 7500 miles. I don't care what anyone says, it's MILEAGE based.
