Reprogram ecm & replace 02 control module
Old Nov 2, 2007 | 08:55 PM
  #31
KMKDiesel's Avatar
Originally Posted by Flattman
How do you know how to tell if a truck is regenerating at idle if you don't have an egt guage? Since my flash last week, I've noticed there are times at idle when the truck shakes more than other times. The glass in the mirrors really shake.
Have you noticed if yours idle differently when it's regenerating?
A huge diff at idle. 800 rpms and egts 900 truck shakes and stumbles like it wants to quit, you can deffintly tell its in regen I have a chip that tells me when it is regenerating. I think that is what is happening to you it is regenerating. I think I seen some little company had a box you plugged in and all it did was tell you if it was regenerating or not. I will see if I can find it.
Old Nov 2, 2007 | 09:00 PM
  #32
Flattman's Avatar
Exactly! It acts like some old carbureted cars when you blipped the throttle real hard, it would take them a while to settle into their regular idle.
It happened again tonight as I pulled off the freeway. At least I know what's happening. Definitely reminds you of the phrase, "Dodge makes it, Cummins shakes it"!
Old Nov 2, 2007 | 09:03 PM
  #33
KMKDiesel's Avatar
Well at least now you can some what tell when you are regenerating. Thats always a plus.
Old Nov 3, 2007 | 09:35 AM
  #34
bob4x4's Avatar
Originally Posted by DJENSEN9367
called dealer, replaces oxygen sensor as under certain circumstances it won't report a problem, reflash ecm to recognize new part, wont have parts for 7 to 10 days.
That's o2 module not sensor that gets replaced..............
Bob
Old Nov 3, 2007 | 09:37 AM
  #35
bob4x4's Avatar
Great, had mine in last week to reprogram the ECU and now it shows up on the list to be done. I've always had great timing.
No worries...........your half way done
Bob
Old Nov 3, 2007 | 09:39 AM
  #36
bob4x4's Avatar
Originally Posted by cadent47
Got mine done today, and a reflash on the TCM. Only drove it 2 miles to the house, no opinion yet.
You do not have a tcm.................
Bob
Old Nov 3, 2007 | 09:40 AM
  #37
bob4x4's Avatar
Originally Posted by ccoop769
Dealer told me about the recall. Is the repgrogram AU???
He said the recall had to do something with the exhaust brake
AU or AG depending on model plus replacing the o2 module
Bob
Old Nov 3, 2007 | 10:10 AM
  #38
DJENSEN9367's Avatar
Bob
https://dealerconnect.chrysler.com/p...ervice/G30.pdf
pdf calls it the oxygen sensor
Old Nov 3, 2007 | 12:14 PM
  #39
vzdude's Avatar
DTR's 'Go to Guy'
Bob
PDF states replace o2 sensor module to be exact.
Bob
TCM is an integral part of the ecm, but still has a separate flash updates.
See above........o2 sensor module to be exact.
Old Nov 3, 2007 | 01:33 PM
  #40
Mikedeere's Avatar
Same here, Got my call Thursday. Orderd part,gonna give a call when it is in
Old Nov 3, 2007 | 05:01 PM
  #41
KMKDiesel's Avatar
Originally Posted by RiddlerLS1
hmm interesting.... ill have my ppl check into that when i take mine in.
there is actually right now 2 different part #s related to the AU flash, I did one and then the next day the part # had changed but it stil had the AU suffix after the part #. I contacted STAR and they told me that yes it is different than the other one but not by much.
This is quoted by a tech from dodge bigtxdually
Old Nov 3, 2007 | 09:05 PM
  #42
markgyver's Avatar
I had my 02 module and flash done today,I was gonna bring it in because its been kinda doggie lately.I have 7500 miles and it hasnt been running as good as when it was new, so anyway i get the recall done and i take off from the dealer and first thing i notice is the exaust brake is on at idle full bore.So i turn around to go back to dealer and im goin about 25 through town when the truck bucks really bad and we thought we got hit from behind it was that bad.But after that exaust brake worked normal. I documented this with dealer and i was on my way home.Im live about 200 miles from the dealer. The mileage is better, and shes back to full power so im happy with it.
Old Nov 3, 2007 | 10:14 PM
  #43
shooter_d's Avatar
Should I put my baffle back in before I go in?
Old Nov 3, 2007 | 11:20 PM
  #44
KMKDiesel's Avatar
As easy as it is on the 6.7 I would because of some dealers.
Old Nov 6, 2007 | 09:39 AM
  #45
MtnTrucker's Avatar
I went in yesterday and had the sensor module/reflash recall performed. I was in and out of the dealership within 1 hour. The tech told me that he replaced the module but that I already had the correct flash revision and no update was required.
There have been reports on this forum that the flash with this recall is totally new and it makes the truck maintain active regen at an idle. If the tech is being straight with me, that doesn't appear to be the case, otherwise he would have updated my flash. I am running on the AU flash that was installed 2-3 months ago to address the P0245 EGR CEL code.
I can't notice any difference in the way the truck runs or performs since completing the recall work. And, I haven't had any CEL's or problems since the AU flash was installed back in late August.
ramruff
20
May 10, 2007 06:07 PM
booman70
Sep 12, 2006 07:43 PM
RickCJ
Nov 12, 2005 10:54 PM
MACADO
Aug 21, 2005 10:43 PM
axpilot
May 20, 2004 09:55 PM
