Regen
Old May 17, 2010 | 12:26 PM
calicowade's Avatar
Regen
This is probably a stupid question but how do I know if my truck goes into regen mode . I have never seen any indication that it has ever done it . I do not drive in town very much and I have the EGR valve unplugged and its completely stock . I also have 60,000 miles on this 2007 6.7 liter 6sp manual .
Old May 17, 2010 | 03:33 PM
mega-engr's Avatar
"California Style"
Unless you have a monitor like the Edge Insight, you will not know. There are some tell-tale signs, but the computer on the truck only lets you know when you're steps away from limp mode and neading to go to the dealer. Passive regen is the truck doing its thing without notifying you that it is doing it. Active regen is when the overhead tells you it is clogged and you better not doing anything else except take it on a speed run to make sure it regens completely.
Old May 17, 2010 | 07:44 PM
sabercat's Avatar
Only way that I can see it is in regen, and only guessing, is the fuel milage drops down
Old May 18, 2010 | 02:48 PM
jswar's Avatar
If I'm driving in town, at lower speeds, I can smell diesel fuel burning. I can't tell much in the way that the trucks performs. When I shut the truck off during regen there's a sound coming from underneath that's something like a cutting torch that tails off to nothing as the truck shuts off...like a torch would if its wide open and the acetylene valve is gradually turned off.
Old May 18, 2010 | 07:03 PM
Blake Clark's Avatar
Well telling when it does regen is tricky.
I can tell you, for a fact, how to make it so you can tell when it doesent!
Old May 26, 2010 | 08:32 AM
Navy7797's Avatar
regen
I put a insight on my truck and then took a road trip, 6000 miles worth. This is what I found
1st regen at 80 miles from house lasted 14 minutes
2nd regen 200 miles later lasted 14 minutes
3rd regen 245 later lasted 14 minutes
all the above was while empty/no load and running 80mph.
Got tired of seeeing the regen flash up on the screen so I shut it off till I picked up my 5er.
Towing the 5er,toy hauler lots of drag, 9300 lbs, and running 65-70 mph
1st reg 215 miles
2nd regen 303 miles
3rd regen 320 miles
These too lasted 14 minutes each.
Whats all this mean ? I say it doesn't ready matter how hard you work your truck its still going to regen.
When it was in regen I could not tell that it was except for the insight, no power gain or loss, no temp increase, and the overhead lair is just not worth looking at as far as mpg.
One thing I do know is that these trucks have the POWER and I love the Engine Brake !
Old May 28, 2010 | 12:02 PM
kb7kuh's Avatar
I have a 1 mile drive to work and live in a small town. No freeways around and my overhead regen comes on about once a month. I make a high speed run over a small hill on the hwy and it goes out. It starts out saying, cat is 80% full, then on to 90% and the next step is "see dealer for service" "power is reduced". I still do the quick run and it does clear it. This is the only thing I dislike about the truck!
Old May 28, 2010 | 01:49 PM
klx650a2's Avatar
Trust on this, get the delete pipe and the smarty. The 6.7 will thank you for it...
Old May 28, 2010 | 02:33 PM
kb7kuh's Avatar
I'm leasing it and don't / cant do much. I do plan on buying it when the lease is up in 2 years. It's an 07 3500 and right now it only has 21K on it. After I do buy it, I will look into all sorts of mods.
What is the delete pipe? Also would disconnecting the EGR help, and if taken if for service reconnected, can they tell? Anything I can do that will improve mileage ect. and not void the warr. would be nice.
Old May 28, 2010 | 06:38 PM
mega-engr's Avatar
"California Style"
If that is your plan they don't wait. The delete pipe replaces the two big cans and is a bolt in/out. You need a programmer for the computer like the Smarty which provides all sorts of options for you. The EGR delete requires nothing but 5 minutes.
You can put it back if you don't want to keep or for any other reason you may need to rather easily.
Old May 29, 2010 | 01:28 PM
klx650a2's Avatar
^^^ That is what I did. This truck is leased for my side business and I'm going to buy when it comes due. Therefore I did the deletes and am much happier.
Old May 29, 2010 | 05:59 PM
rraulston's Avatar
i heard when the cruise controll is on it wont regen?????T/F????
Old May 29, 2010 | 06:00 PM
rraulston's Avatar
its official, my brand new 09 3k miles gets 13 mpg....
Old May 30, 2010 | 10:02 AM
Chubby's Avatar
Whats Regen I havent seen that since 3000 miles HAHAHA ?
Old May 30, 2010 | 01:15 PM
Not true.
How do you spell relief D-E-L-E-T-E
I thought that was purchasing a new generator for hurricane season....
