Power Service Additive and 6.7
check the bottle. The last batch of Fleetgaurd winter additive I had (last week), said NOT to use it on 07 emissions compliant vehicles.
Personally, I think its a bunch of bull. I bet your EGR valve is sooting up at the same rate without using any additive. I am also concerned with the lubricity of no1 arctic fuel.
I thought the ash comes from the oil and that's why you have to buy the expensive "low ash" oil. Now they are saying it comes from fuel and fuel additives. Something's fishy.
Well being I brought up Valvoline fuel additive, I sent them an Email to see if they say its Ok to use in the 6.7 Cummins. I'll let you know what they have to say if they reply.
I got a reply from Valvoline just now and below is what they had to say:
Absolutely, it is 100% fine for use in the 2007 Cummins.
To: VWEBMAIL@Ashland
cc:
Subject: Site feedback from Valvoline.com
The following person submitted a question or comment via the Contact us form of type Ask SynPower
First Name: Charles
Last Name:
Address1:
Address2:
City:
State: --
Zip Code:
Phone:
Email Address: dblr@
Comments:
I would like to know if your diesel fuel additive is safe to use in a 2007 Cummins 6.7L diesel engine.
cc:
First Name: Charles
Last Name:
Address1:
Address2:
City:
State: --
Zip Code:
Phone:
Comments:
If it's not broke - don't try to fix it.
I, Like Jack Thorpe, have never used any additives in 6.5 years of Cummins ownership. I have never had a fuel gelling or lubricity problem. It's money down the drain, and simply increases the cost of fueling up your truck.
X2
I've had dump trucks with Detroit Diesels, various Cummins diesels, excavating equipment with Cat motors, all with hundreds of thousands of miles and/or operating hours. Plus 3 powerstrokes with over 500,000 miles total between them, and I have never ran a drop of fuel additive in any of them. I've never had a problem with fuel unless it was -30 degrees and then it didn't matter whether you were running additives or not. As long as you use fresh fuel and not something thats been sitting in a farmers storage tank for 2 years with algae growing in it, additives are a waste IMHO
X2
I'm not trying to be argumentative, pig headed or force an agenda, but I worry we're part of this large scale experiment to see how "clean" the fuel and oils can get before they fail to provide the lubrication protection they were meant to provide.
DTR Founder
I don't think you're being a pain or being argumentative. Your questions are valid as thousands of owners will be wondering the same thing. My take on it is that only time will tell what will REALLY happen. Once these engines have a lot more miles on them and people either have problems or don't, only then will we know for sure.
My philosophy on the whole thing is to take a wait and see approach. SOMEONE out there is going to do it, and when they finally post their results a year or two from now, then we might have a better idea. I'm in safe mode myself, and will not dare add this stuff to my tank, especially when it comes from the manufacturer in big bold letters not to do so. I would hate for someone to take their truck in for warranty work only to find it void because they didn't read or they ignored instructions.
As I said before, it's just my personal philosophy on the whole thing. I know this sounds mean, but I hope someone DOES religiously add this stuff to their tank because I'm truly curious about what the end result will be.
I add PS or Schaeffers' with every fill-up in the winter even though the stations/suppliers around here go to winter blend just to be sure they didn't forget AND if the truck sits all night at 20-30 below the anti-gel makes it certain that you'll be OK.
Guys, be careful with the advice in this thread. I was specifically asking this question for myself and others regarding the 6.7 motor. Your sig shows you with a 5.9 so I want to be sure folks don't read this and become misinformed.
cc:
First Name: Charles
Last Name:
Address1:
Address2:
City:
State: --
Zip Code:
Phone:
Comments:
cc:
First Name: Charles
Last Name:
Address1:
Address2:
City:
State: --
Zip Code:
Phone:
Comments:
...and I guess that means it is? Is that gospel? You've got a guy on here with real world experience with a "gummed up EGR valve." I think his fuel additive was for a 6.7 wasn't it? Probably could've emailed them also and would have received the same reply.
BigD
Yep, you're right ... guess I got caught up in the posts relating "no additive in ANY diesels for 'X' years" .....
My $0.02
You know, with all the reading I have done on various forums about not using fuel additives on the new 6.7L, I have never received any WRITTEN information from Dodge saying not to use them. The owners manual says that they are not necessary, but it does not say NOT to use them. I have been using Stanadyne Performance Formula, with a bit of their Lubricity Formula added for good measure, with every fillup since day one. So far so good.
