Oil Change Indicator
Old Dec 26, 2010 | 01:55 PM
ctzdavis's Avatar
Question Oil Change Indicator
I recently changed my oil. Less than 200 miles ago. The change oil indicator has come on three times since the oil change. What gives? I have a 2008 6.7 with 40,000 miles on it. The truck is bone stock, no mods. On another note my fuel mileage has gone down the tube since a dealer replaced the turbo and reflashed the computer 8000 miles ago.
Old Dec 26, 2010 | 04:57 PM
ctzdavis's Avatar
And yes I did reset the indicator every time.
Old Dec 28, 2010 | 09:57 AM
JT's 6.7's Avatar
Just a random thought. Have you checked your batteries? Mine did all kinds of strange things when one of my batteries started to go. I seem to recall the Oil change indicator going off.
Old Dec 28, 2010 | 11:12 AM
ctzdavis's Avatar
No I did not check the batteries. But I will now. Thank you.
Old Dec 28, 2010 | 03:41 PM
mr. ed's Avatar
I agree with JT. I had to replace a bad passenger side battery earlier this year for the same reason. I was having the lightning bolt lamp and CEL come on each time I started the truck on a cold morning. Also had a strange rattling sound under the dash while starting. And if I recall, my oil change indicator was coming on too soon, also. I also recently replaced the other battery. Both are from Auto Zone (the batteries with the red tops).
Old Jan 2, 2011 | 01:54 PM
ctzdavis's Avatar
So it decided not to start two nights ago. 15 degrees at 3 am. I removed all of the terminal cleaned then etc. Starts fine now same temp out side. Still have the oil change light coming on. I am going to go get the batteries tested and see what they say. Thank you for your help.
Chad
fairbank
Dec 8, 2012 02:22 PM
JARHEAD
Sep 28, 2011 09:37 AM
8bm
Aug 31, 2009 04:44 AM
MikeRP
17
Jun 12, 2008 07:48 PM
Dodgezilla
Mar 29, 2008 02:34 PM
