Oil Change Indicator - ??
Old Jun 11, 2008 | 09:40 PM
Azzy's Avatar
Originally Posted by Pirate
My oil change indicator came on and I tried to reset it with the key on and depress the accelerator slowly 3times then key off. It didn't reset. Any idea what I may be doing wrong or is there another way to reset it?
That's def how you do it. Did you maybe not push the acc all the way down? How many times did you try it?
Old Jun 11, 2008 | 10:46 PM
dodgeram_dude's Avatar
You might actually be performing the procedure too slowly. Make sure you push the go pedal all the way to the floor, but do it 3 times within say, 3 seconds. The whole thing must be done within a 10 second time frame... ignition to the 'on' position, press pedal 3 times, ignition to 'off'. It's worked everytime that I've done it this way. Just a suggestion... I hope it works.
Old Jun 12, 2008 | 07:48 PM
Pirate's Avatar
Thanks for the 10 second time frame, that was the problem. I just did it too slowly.
fairbank
Dec 8, 2012 02:22 PM
JARHEAD
Sep 28, 2011 09:37 AM
ctzdavis
Jan 2, 2011 01:54 PM
8bm
Aug 31, 2009 04:44 AM
Dodgezilla
Mar 29, 2008 02:34 PM
