light load button ??
Old Jan 17, 2012 | 06:19 PM
thomasb's Avatar
not exactly sure how or what this button does. was on when i bought the truck i pushed it and now it flashes every time i try to turn it back on. any help is appreciated.
Old Jan 17, 2012 | 10:04 PM
sabersix's Avatar
You have a 2500, right?
I believe that works with the Tire Pressure monitor system so that you can run lower tire pressure with a light (or no) load and not get a pressure warning. Should be in your owner's manual.
Old Feb 9, 2012 | 09:02 PM
notrader's Avatar
that is so you can run lower pressure in your "rear" tires. 45 PSI for light load in my 2500 4x4
Old Feb 23, 2012 | 11:11 AM
Lil Dog's Avatar
There is a procedure to engage that so you don't get the TPMS warning light with pressures under the heavy load setpoints. There is a sticker on the door sill with the pressures. I have gotten away with 48 psi in the rears to engage the light load.
Budman57
30
Feb 4, 2013 01:21 PM
1-2-3
Dec 18, 2012 06:38 AM
Tedonlin150
Feb 4, 2010 11:37 AM
spitzair
Oct 23, 2009 10:10 PM
can17
Nov 10, 2008 02:53 PM
