Jumpers hooked up backwards. 2008 2500
Old Apr 2, 2018 | 11:38 PM
Apantslessman's Avatar
so yes. im an idiot, i hooked my cables up backwards. and yes i know not to do that. now that thats out of the way.
i replaced 3 fuses, and one fusable link. when i turn the key on, it runs through its starting procedure like normal, EXCEPT the grid heater light doesnt come on, and wont turn over. as far as i can see everything else works. radio, lights, Power ports. also the programmer (Edge Juice) tries to clear DTC, and fails. i cant retrieve codes either.
other than in the main fuse panel are there any fuses that i can check? is this symptomatic of the PCM? anyway to verify if thats what the issue is? i have followed the main battery lines, and found no melted lines or connections,
Old Apr 3, 2018 | 08:19 AM
John_P's Avatar
Sir:
First off, welcome to DTR! Sorry to hear of the problems you are having. But believe me, you are not the first person here to have made that mistake on the cables!
With reversing those cables you may have damaged something in the PCM/ECM or the wiring and relays in that system. I would recommend taking it to either a Dodge Dealer or independent shop where they can hook up a DRB Scanner to your truck and see EXACTLY what may have been damaged.
It may be something simpler than damage to the PCM/ECM which can be easily changed or repaired. I have seen some of my friends do this and have minor damage, but I have also seen damage to the PCM/ECM Units.
Good luck.
John_P
Red3quarter
Sep 20, 2008 11:30 PM
Chrisreyn
May 17, 2008 10:55 PM
Chrisreyn
Jan 13, 2008 06:30 PM
Ghost Ram
Oct 17, 2007 10:11 PM
Mexstan
Oct 19, 2003 12:09 AM
