Injectors Junk, Chrysler wants $10'200 to replace
Old Apr 1, 2009 | 12:27 AM
  #46
7.3's Avatar
7.3
So what happened to the original poster?
Old Apr 2, 2009 | 09:07 AM
  #47
b4black's Avatar
I have a dealership invoice in front of me for work on a 2008 6.7L CTD.
68027067AB Injector List = $1440.00 each
Old Apr 2, 2009 | 05:40 PM
  #48
Hounddog's Avatar
That kind of money for a injector.Absurd!
Old Apr 5, 2009 | 10:26 AM
  #49
cdhd2001's Avatar
Originally Posted by coolbreeze
Maybe mr. ed will chime in here. Anyway, on another forum, he mentioned a rough idle problem with his 07.5. He says 8oz of Power Service in a tank of fuel cleared it up. He hadn't been using any additive prior, and used it as a last resort, not wanting the dealer messing with his engine.
I would definitely get another opinion.
You haven't been using any home-brew additives have you? Like ATF or something in your fuel?
My 2003 Duramax had a similar rough idle problem. Only thing that fixed it was Power Service every other tank. Go longer than that and the idle surge would come back. Worked for 80k miles.
Old Apr 5, 2009 | 01:53 PM
  #50
p035970's Avatar
Find a new dealer.
A few miles over the 100,000 shouldn't be that big of a deal. A good dealer will go to bat for you when its that close. I have had my dealer here warranty 3/36 items up into the 40,000 mile range. As far as someone saying that they will just look for a late model 5.9 and avoid these issues, the injectors for them aren't cheap either. They are also blessed with basically no water separator. The dealer diesel mechanic at my dealership in Mt. Pleasant, Texas (and yes he is a real and a good diesel mechanic) told me that if the water in fuel light comes on it is basically already too late on these models with the drop in canister. At least the 6.7's have a better system on them. If the injecors are having problems because of water, it breaks down to buying fuel where is is sold in high volumes and draining the water of every couple of thousand miles whether it needs it or not. Sorry for the long post and I'm sorry for the trouble your having with your dealership. All injectors going bad at the same time is a very rare occurance without water contamination, so this sounds like a line of BS. I would run it like I stole it for a little while to see if it clears up.
Old Apr 6, 2009 | 12:41 PM
  #51
Hounddog's Avatar
If Power Service has to be used every tank there is something sticking.A bad FCA, one of the checks is a fuel lube or ashless two stroke oil and if it clears up and then goes to running poor when not used the FCA is sticking.I drain some out the fuel cannister every tank of fuel.
Old Apr 6, 2009 | 07:41 PM
  #52
mr. ed's Avatar
What is "FCA" ?
Just curious....what does "FCA" stands for...?
Old Apr 6, 2009 | 08:52 PM
  #53
Hounddog's Avatar
Fuel Control Actuator.Fuel solenoid on the back of the high pressure injection pump.
Old Jul 2, 2009 | 06:53 PM
  #54
tinbanger's Avatar
call cummins NW (503) 289-0900 @ $463 an injector that seems a bit more reasonable than 1500 each........
Old Jul 5, 2009 | 07:15 AM
  #55
Pull Dog's Avatar
Dealers and shops that charge this kind of money are preying on people who do not know what to do, have lots of money, or do not have the Internet!
I would rent a mule and pull that truck to another shop or pull it home and attempt it myself before giving those jerks $10k. A good Internet search can give you tremendous alternatives and ideas!!!!
04ctd
Mar 11, 2008 08:59 AM
mitternocht
Apr 6, 2007 09:14 PM
RickG
Nov 3, 2006 02:44 PM
jeeptjstud
Apr 25, 2006 08:17 AM
