I'm tired
Old Jun 24, 2010 | 03:21 PM
bayshorebrawler's Avatar
I'm tired
I recently took the truck in because of the exhaust brake coming on at its own leisure. They cleaned the particulate filter, exhaust system, 2 sensors 02sen an turbo sen. Basically de soot the entire system. I had to rent a truck for a week an 2 days while mine was in the shop.that cost me almost 375. an then i got my bill from the *********** 1652.37 I liked to EDIT my pants, i have drove the truck 2 days now,now the ck engine lite is back on an another little red light like a (lighting bolt) is on also.I can't believe that they can't fix this **** truck
Old Jun 24, 2010 | 03:23 PM
cbrahs's Avatar
lightening bolt is throttle valve.
Old Jun 24, 2010 | 03:33 PM
The truck didn't run any different after i had the work done. I did notice that its a little slow to start after i got it back. Kinda like a week battery, thats when the red light came on. That not good i just replaced both batteries in April.
Old Jun 24, 2010 | 04:03 PM
cbrahs's Avatar
1 single bad battery will cause what you are experiencing too. have them load tested. if they are that new, it won't cost ya nothin
Old Jun 24, 2010 | 04:31 PM
BigIron70's Avatar
Cummins Guru
Originally Posted by bayshorebrawler
I recently took the truck in because of the exhaust brake coming on at its own leisure. They cleaned the particulate filter, exhaust system, 2 sensors 02sen an turbo sen. Basically de soot the entire system. I had to rent a truck for a week an 2 days while mine was in the shop.that cost me almost 375. an then i got my bill from the *********** 1652.37 I liked to edit my pants, i have drove the truck 2 days now,now the ck engine lite is back on an another little red light like a (lighting bolt) is on also.I can't believe that they can't fix this **** truck
6.7 Cummins have had some issues with turbos and sensors getting sooted up. Doing a regen on your truck indicates you most likely don't drive it that much or for long periods of time. Some states require the first time cleaning of EGR and cooler also crankcase breather to be on Chryslers dime.
67500 108000 54 When prompted by the Engine Oil Indicator System, the engine oil and filter must be changed. If not prompted by the Engine Oil Indicator System within 7,500 miles (12 000 km) or 6 months since the last oil and filter change, change the engine oil and engine oil filter. Under no circumstances should oil change intervals exceed 7,500 miles (12 000 km) or 6 months, whichever comes first.
Rotate tires.
Lubricate front drive shaft fitting (4x4).
Lubricate outer tie rod ends.
Inspect the front suspension, tie rod ends, and boot seals, replace if necessary.
Inspect brake linings.
Inspect and adjust parking brake if necessary.
Replace Crankcase Ventilation Filter (CCV).
Clean EGR Valve**.
Clean EGR Cooler**.
If you live in any of these states there is NO CHARGE for the required cleaning.
**The EGR Valve and EGR Cooler maintenance will be covered by the manufacturer only at this maintenance interval, for vehicles registered in California, Maine, Massachusetts, New York and Vermont.
Old Jun 24, 2010 | 05:10 PM
I drive 3 to 5 hundred a day i'm a service man. The truck is out of warranty it now has 121935 miles. This is my work truck and personal it does get driven. Since day one this truck has been in the shop it has never been fixed yet. I do think i got the lemon.
Old Jun 24, 2010 | 05:13 PM
madhat's Avatar
Administrator/Jarhead
Please post within the limits of the forum rules.
Old Jun 24, 2010 | 06:36 PM
Blake Clark's Avatar
I do think you need to delete....
Since you have no warranty you have no worries. Get a Smarty (Sr or Jr) and delete full exhaust, EGR, EGR Cooler, and Throttle valve.
Problem solved.
Old Jun 25, 2010 | 06:50 PM
mega-engr's Avatar
"California Style"
Problem solved.
x2 this is the solution. You will be a happy camper after completing this!
Old Jul 6, 2010 | 11:12 PM
91.5 beater's Avatar
x3 i ordered my kit the same night i bought my truck, i got the h&s performance kit from www.rollinsmokediesel.com it was about $900 to my door, no signs of any problems, averaging about 18 city and hwy combined driving empty and like a grandma, about 15mpg towing, it is better than when it was stock, DO the delete and dont look back!!!!!
Jmac
Jul 6, 2004 04:39 AM
DieselDaze
Feb 28, 2004 02:40 AM
NWDave
Mar 24, 2003 10:17 PM
Feb 24, 2003 03:42 PM
JODUALLY
Nov 19, 2002 12:06 PM
