Idle engine picth change
Old Jan 21, 2010 | 12:12 AM
kingofdodge7131's Avatar
Hey guys. Quick question. Wwhen my truck sits for 6.7 say 30 seconds. Makes a noise change. Not quite idle up. Kinds like exhaust brake. Also. I have perform service sign on and manual says that crank case filter needs changed. Can that fall off?
Old Jan 22, 2010 | 09:29 AM
BigIron70's Avatar
Cummins Guru
Crankcase breather filter is changed at 67K, on Chrysler's dime the first time. Most likey noise is EGR valve opening and closing or EGR cooler bypass valve closing. It will make a noticeable engine noise change. To reset light key on step on brake twice then gas pedal twice turn off key. To reset oil change light, key on step on gas pedal three times to the floor and turn off ign. key.
Old Jan 23, 2010 | 09:06 AM
Is there a tsb or something for this?
Old Jan 25, 2010 | 11:10 AM
DWRDodge6.7's Avatar
Every vehicle that I have ever owned changes pitch not long after starting and again after full warm up. It's normal.
Old Jan 26, 2010 | 11:37 AM
the engine noise isnt a normal warm up sound you drive a hour and then sit, but the egr makes sense, it runs fine i just wanted to know what part was doing it
is there a notice for the first filter change? i couldnt find anything on it
Old Mar 11, 2010 | 06:21 PM
jond1's Avatar
Never thought Chrysler would pay for the change?
Old Mar 11, 2010 | 07:03 PM
klx650a2's Avatar
Unfortunately Chrysler would not go good for my CCV change... $178.00 just for the filter at the dealer, or $72.00 at Cummins. I did it myself, easy to do with 1 to 2 beer and lots of looking around under there...
Old Mar 11, 2010 | 07:38 PM
Blake Clark's Avatar
How many miles did you change it at?
Im knocking on 50,000 and mine probably isnt far out.
Old Mar 12, 2010 | 12:01 AM
got_soot's Avatar
Soot For Brains!
Is this a must?
Old Mar 12, 2010 | 05:17 AM
Oh and to the OP, mine used to change pitches. Since the egr deletes, it doesnt any more.
Old Mar 12, 2010 | 08:58 AM
klx650a2's Avatar
Blake, I changed mine at 65,000 miles. It was dirty, but no oil dripping back into the turbo. Very easy job to do.
Old Mar 12, 2010 | 01:58 PM
I figured it wouldnt be all that bad. I think I saw somewhere that you can just vent it to atmosphere and plug the turbo inlet. May look into that.
Old Mar 12, 2010 | 07:31 PM
mega-engr's Avatar
"California Style"
That would be nice. I think Ratl Ratl was saying something about this. A write-up on preferred method would be .
Old Mar 14, 2010 | 01:21 AM
J BODY's Avatar
Idle change is normal, especially if you have the newer updates. They use change in fueling and turbo settings to keep the exhaust and engine temps up to prevent excessive sooting.
bradshaw106
Nov 27, 2009 12:06 PM
jmccart
13
May 27, 2009 09:45 PM
Smokin'02
Feb 9, 2009 08:43 PM
markm4
Jul 29, 2007 11:16 AM
doitl8r
Jun 4, 2004 11:14 AM
