How difficult to remove injectors from a 6.7l?
Old Jan 19, 2010 | 09:51 PM
gts95's Avatar
Question How difficult to remove injectors from a 6.7l?
How difficult is it to remove and reinstall injectors on a 2008? I have never touched one of the engine....I did an injectors swap on my old '93 First Gen but I hear these things are completely different! The '93 was a piece of cake.
Reason for needing to do this is to spin a motor over that has possibly injested water (flood). I imagine there is no other way of verifying there no water in the cylinders besides popping the injectors and spinning the motor over?
Old Jan 19, 2010 | 09:57 PM
6speedcowboy's Avatar
not too bad. its a bit more work though. most important thing is that you keep them in order and that they go back into the same cylinder they came from
Old Jan 19, 2010 | 11:51 PM
kingofdodge7131's Avatar
i believe they are coded for each cylinder, not 100% sure though, engine wont even fire if they arnt in the right place
Old Jan 20, 2010 | 09:30 AM
gts95's Avatar
Yeah, I read about the necessity of reinstalling them in the same cylinders where they were removed.
Are any special tools needed?
Old Jan 20, 2010 | 03:50 PM
they are about the same as doing injectors on a 5.9. heres a link to ddp's site for injector r&r on a 5.9 cummins.
http://dynomitediesel.com/uploads/fi...ns_6042009.pdf
Old Jan 22, 2010 | 04:00 PM
BigIron70's Avatar
Cummins Guru
Injectors are coded and if changed will require inputing correct code into PCM. This is a calibration code for every injector and tells computer exactly how much fuel is coming out of injector. If not entered will effect engine operation and will set a DTC.
RoadDiesel
Aug 7, 2012 06:06 PM
89dieselkong
Nov 21, 2010 10:06 AM
jeeptjstud
Mar 24, 2006 01:09 AM
Dodgezilla
Jul 17, 2004 05:24 AM
Jones0027
Feb 6, 2003 09:16 PM
