HELP---DEALER says $4,400!!!!????
Old Oct 27, 2007 | 05:12 PM
  #31
ccoop769's Avatar
Originally Posted by #2 only
GRAVITY FED TANKS ARE ONLY ILLEGAL IF-
IT FEEDS THE FUEL DIRECTLY TO THE CARBURETOR OR INJECTOR.
I saw that, thanks for reminding me. Its nice to learn the real laws instead of people telling me their opionions.
Old Oct 27, 2007 | 05:23 PM
  #32
#2 only's Avatar
THE MANUFACTURERS SAY, IT'S ILLEGAL.THAT'S ONLY HALF THE TRUTH.THEY WANT YOUR BUSINESS EVEN IF THEY LIE.YOU CAN PUT A GRAVITY FEED SYSTEM IN AS LONG AS YOU PLUMB IT TO YOUR MAIN TANK AND IT HAS EITHER A HAND BALL VALVE OR AN ELECTRIC VALVE WITH A SWITCH IN THE CAB.
Old Oct 30, 2007 | 04:34 PM
  #33
scootertrash35's Avatar
SOMEBODY SHOOT ME!!!!!!!!!!
friday at noon i dropped truck at second dealer(team dodge-huntsville)and explained about bad injector(fuel in oil)and lift pump failure.this is tuesday at 4:15 pm ,i call to get a update on progress.they tell me truck runs fine,so they have been driving it up and down the highway with the scanner hooked to it!! i said do you not recall me saying fuel in oil??? he says yeah i'm pretty sure i told him.so why in the *#!* are you driving it?
Old Oct 30, 2007 | 04:41 PM
  #34
wreedCTD's Avatar
maybe you should have taken it down to Tim @ Helfman? Maybe you just got some bad fuel?
Old Oct 30, 2007 | 04:46 PM
  #35
yeah i talked to tim,but team dodge said same thing and it was a little closer.bad fuel wouldn't equal fuel in oil,and when it died i pulled fuel filter and hit key-no fuel to cannister.then after it sat all day it would run.
Old Nov 13, 2007 | 05:43 PM
  #36
wreedCTD's Avatar
did you ever get your truck fixed? whats going on with it?
Old Nov 13, 2007 | 06:50 PM
  #37
the verdict so far is quick car overfilled the oil,and after 2 weeks the dealer said to come get it because it's running fine and won't repeat the problem with the scanner hooked up(they drove it 132 miles)so i picked it up and have put about 1500 miles on it with no problems yet
i'm looking into a walbro lift pump so i won't get stranded again,other than that i don't know what to do
Old Nov 13, 2007 | 07:01 PM
  #38
coolbreeze's Avatar
This is a 07.5 or 08?
Old Nov 13, 2007 | 07:36 PM
  #39
'06 5.9...........
Old Nov 13, 2007 | 07:58 PM
  #40
coolbreeze's Avatar
I see, in the wrong forum.
jqc99
Jan 14, 2010 02:49 PM
BUSAHAULER
16
Feb 20, 2007 06:13 PM
PsRumors
Mar 3, 2006 05:45 PM
dodgedude361
19
May 19, 2005 10:00 PM
admin
20
Mar 9, 2003 09:23 PM
