HELP---DEALER says $4,400!!!!????
dealer says warranty voided on bad injector,and bad lift pump because i have a dot legal aux fuel tank in the bed and it gravity feeds (through an inline filter)into filler neck-between cap and tank.the truck is 06' with 83,000 miles.they say any mod to a vehicle voids all warranty!even though i am double filtering the fuel.it's not like i modified factory filter or cut line between tank and engine or cut a hole in my tank!i know there thousands of other hotshotters out there with similar setup.what to do ???????????????
EDIT:they told me the leaky inj. caused the pump failure so whts that have to do with my tank?
call Tim at Helfman dodge and explain your situation and see what he says. I have had nothing but good luck and honesty with this guy.
Tim McLean
Service Manager
Direct:713-533-6252
Fax:713-533-6272
Email:tmclean@helfmandodge.com
Tim McLean
Service Manager
Direct:713-533-6252
Fax:713-533-6272
thanks,i called him and he said sounds like BS
Here's a link from Transferflow explaining things a little bit.
http://www.transferflow.com/fuel_tank_regulations.html
