HELP---DEALER says $4,400!!!!????
Old Oct 26, 2007 | 03:19 PM
ccoop769's Avatar
Originally Posted by Flattman
I only know because I've been researching a tank for my truck. Man they're expensive. But now I'm going to pay attention to this thread very closely to see how it shakes out.
I enjoy the express ufs!! I only paid 950 shipped. But I guess that is expensive
Old Oct 26, 2007 | 04:52 PM
scootertrash35's Avatar
Originally Posted by rustyshakelford
i think hes being taken care of now!
brett
thanks for the help Brett,got it up to Team Dodge Huntsville and they said it shouldn't be a problem but they won't know if Demontrond 'flagged' it until monday.then i got my first peek at some 08' 4500 and 5500s
Old Oct 26, 2007 | 04:54 PM
Totallyrad's Avatar
Hoping for the best here John.
Old Oct 26, 2007 | 05:04 PM
i'm keeping my fingers crossed! kinda hard to type though
Old Oct 26, 2007 | 05:05 PM
new2ctd's Avatar
Gravity feed Aux tanks are not illegal.
http://www.fmcsa.dot.gov/rules-regul...csr/393.65.htm
Old Oct 26, 2007 | 07:05 PM
ccoop769's Avatar
Im just saying its illegal cause 3 different mechanics of different truck shops that sell aux tanks say they cant install the plumbing to make gravity fed.
Old Oct 26, 2007 | 07:33 PM
Totallyrad's Avatar
Now that you mention it, I can't think of any vehicle you can license and drive on the highway, except a motorcycle, that doesn't require a lift pump of some sort. Additionally, I can't speak for all of them, but my 95 Harley has a vacuum operated fuel tank valve. Even if you leave the valve open, it won't allow fuel to flow unless there is a vacuum applied, either from an outside source or from the engine. The engine being the usual source.
Old Oct 26, 2007 | 08:26 PM
coolbreeze's Avatar
'06, and not '07 or '08 correct?
Old Oct 26, 2007 | 09:36 PM
mine is '06
Old Oct 26, 2007 | 09:48 PM
jwb600's Avatar
they sound like they have lost their mind to me
Old Oct 26, 2007 | 10:43 PM
shinkle627's Avatar
Scooter,
did they give you any reason why the injector pump went? I'm new to this site, and not sure if this is an already known fact or not. I spoke with a local cummins guy and he told me that the new ultra low sulfer fuel is loosening up sediment in the tanks and causing fuel filters to clog earlier than they should. He explained any resistance to the injector pump will cause them to go. He has changed many of them, it's more of a cummins issue than gm or ford. For some reason they are sensitive. He told me he installs a indicator light for about $100.00 and that if it gets resistance, it will notify you so you can change filter. Just giving my .02 .... I may just be repeating what everybody knows,
Steve
Old Oct 26, 2007 | 11:35 PM
Originally Posted by shinkle627
Scooter,
Steve
service advisors exact words'leaky injector caused lift pump to go bad'
i've never had a problem with a filter,change every 15k
Old Oct 27, 2007 | 09:33 AM
TonyB's Avatar
That's bassackwards! That is saying too much flow caused the pump to fail!
Tony
Old Oct 27, 2007 | 10:19 AM
Rollin' Smoke's Avatar
someone needs to make a list of GOOD and BAD dealers around the houston area! and I would definately put the first dealer you went to on the BAD list
Old Oct 27, 2007 | 05:10 PM
#2 only's Avatar
Originally Posted by ccoop769
GRAVITY FEED IS ILLEGAL!!!!!! but still bs. ARcher Dodge is cool
GRAVITY FED TANKS ARE ONLY ILLEGAL IF-
IT FEEDS THE FUEL DIRECTLY TO THE CARBURETOR OR INJECTOR.
