First tank from factory is 5% Biodiesel?
Old Apr 4, 2007 | 05:44 PM
C&C Milo's Avatar
Came across this press release.
http://www.biodiesel.org/resources/p...dge_ram_b5.pdf
Does anyone know if it is still true that every truck out of the MO plant comes with biodiesel in the tank?
Old Apr 4, 2007 | 07:07 PM
wreedCTD's Avatar
Im sure it is, i heard most FFV and being filled with ethanol now.
Old Apr 6, 2007 | 01:53 AM
SuperGewl's Avatar
Even if it isn't, don't worry. Do as I do and fiiler up with 100% homemade Biodiesel. The stuff runs much better than regular diesel and passes the test as ULSD anyway. If you make it yourself then you can control the quality yourself.
Old Apr 9, 2007 | 11:25 PM
Desert Dually's Avatar
say what?
you wanna splain that in a bit more detail? I thought you can only run that french fry oil in old Volkwagen's and Mercedes sedans?????
Old Apr 10, 2007 | 08:16 AM
bigblock2stroke's Avatar
running biodiesel and running on vegetable are two completely different things.
Arkapigdiesel
Jun 13, 2007 07:25 AM
Red3quarter
Apr 8, 2007 12:01 AM
AlpineRAM
Oct 3, 2005 05:29 PM
Lightman
Dec 15, 2003 09:23 PM
Lightman
Aug 8, 2003 08:40 AM
