Finally picked up my Cab and Chassis w/pics!
Old Jan 27, 2007 | 06:18 PM
06dually's Avatar
Originally Posted by erics76
It may have 3.73's. I can't find anywhere on the window sticker where it says anything about gear ratio. I'm pretty sure the first truck I drove without cruise or exhaust brake said 4.10 gears in the optional equipment. This truck doesn't say anything, so it may have 3.73. It's been a real problem swaping trucks and beds, can't remember which had what. So what is the difference in the gear ratios in the new and old 6 speed?
The new G-56 6-speed with 3.73's will run about the same rpm's as the old nv5600 6-speed with 4.10's. Alot of people don't like the new one because of the mileage, but I pull pretty heavy with mine and I like the gearing.
Old Jan 27, 2007 | 06:25 PM
erics76's Avatar
Yeah, I'm glad the rpm's end up about the same. I pull pretty heavy too and that's where I like it as well. If they both have the same 1st gear ratio, I hope the little higher gearing in the 07 won't make that big a difference in taking off with a full load.
Old Jan 27, 2007 | 06:40 PM
06dually's Avatar
Actually the g-56 has a much lower first gear ratio so you should be fine. The gear ratios are as follows: 1st gear G-56 6.29 1st gear nv-5600 5.63, 2nd 3.48 - 3.38, 3rd 2.10 - 2.04, 4th 1.38 - 1.39, 5th 1.00 - 1.00, 6th .79 - .73
Old Feb 1, 2007 | 05:41 PM
truckjunkie's Avatar
Is the gear ratio listed on the decal in the glove box like the 06 and below models?
Old Feb 1, 2007 | 09:13 PM
goose2's Avatar
I had posted earlier that I had test-driven a cab and chassis DRW a couple weeks ago. We were going to get it, but it didn't have cruise, so the dealership started looking for one with cruise. Well they found one with cruise and an exhaust brake, but it had a cheap flatbed on it. We talked them into swapping beds. It took them a couple weeks, but it was well worth it. It's got a very different powerband than the 02 it replaces. Feels like it has more power as well. I think the new 6 speed shifts better than the old one. I will have to get used to reverse being all the way left and down. I thought i'd take some pics and post them since this is as clean as it will probably ever be again.
Oh yeah, I looked at the exhaust. There is a sensor right before the muffler, but nothing after. Seems that would make it ok for straight pipe or aftermarket muffler, but I'll probably wait a while until someone else does it first.
That is a nice truck, but I would bet that as short as that thing is it is ruff riding with out a load on her. That could make a bad back badder.
Old Feb 1, 2007 | 09:42 PM
06dually's Avatar
Not listed in the 06's.
Old Feb 3, 2007 | 01:24 AM
06dually's Avatar
Erics76, Just wondering, have you pulled heavy with it yet?? and what are you thoughts?
Old Feb 3, 2007 | 03:14 PM
erics76's Avatar
There's nothing in the glovebox.
The heaviest thing I've pulled so far is a 5 round bale hay hauler that is probably around 8,000lb loaded. So it's not really a challenge. I'm going to be moving 20 head of cattle in a 28 foot trailer on Wednesday. I'll have a better idea on how it is then.
Old Feb 7, 2007 | 01:45 PM
mj007's Avatar
Nice truck!
Old Feb 8, 2007 | 02:55 PM
erics76's Avatar
I hauled 20 cows and 2 bulls yesterday in two loads. The first load was 10 and the second load was 12. They were angus and brangus cows and angus bulls, I figure they averaged 1400lbs. So the first load was around 14,000lbs, and the second 16,800. The pasture I hauled them to, I'd hauled to before in the old 2002 cab and chassis. The new truck definately pulls it better. The best way I can describe it is that in the 2002 truck with around that weight, if you had the gas peddle over 3/4 the way down and then floored it, nothing changed. No more speed. With the new truck, I was able to gain speed easily. It was a definate improvement. I like the exhaust brake alot. The shifter is still irritateing me though. I like the new trans, just not the location of reverse. I don't think it's something I'll just have to get used to either. I really don't like it. Overall i'm impressed with the truck though. It's much more refined than the 2002 it replaced in every detail. I really want to straight pipe it though.
Old Feb 8, 2007 | 03:41 PM
Hillbilly Delux's Avatar
ive towed 21550 which is a 8000 pound 32 foot double deck eby trailer and 900 wienling pigs, running 55 and 60 it does ok, does pull down quite a bit on hills but on the 4 lane running 65 &70 it does much better, ive only gotten around 9.5 to 10 mpg but it only has 1300 miles on it also, then again it runs for about 45 minutes while i load and about an hour when i unload and sweap out pine bedding so it will be better in the summer im sure
DieselRV
Competition / Pulls / OffRoad
0
Jul 16, 2013 03:43 PM
PapeCAT
Cummins Conversions
17
Nov 3, 2010 11:08 PM
2001diesel
14
May 3, 2007 02:05 PM
Dusty Ratcliff
13
Apr 2, 2007 07:13 PM
Holsteinman
Nov 3, 2005 08:12 AM
