Exhaust brake staying on
On my 07, the exhaust brake seems to engage on it own, even if you're on the throttle. I'm almost sure it's the exhaust brake engaging because I can hear it and it puts a load on the truck. Any suggestions on what the problem could be?
I think there was a flash that may cure that, not sure as I have never had mine flashed, and didnt keep up with them.
You running anything other than that MP8 on it???
I would think that its also possible that the slider nozzle being gunked up that might be holding it partially open. I would turn it on and give it a good hard run and and see if that helps.
The Smarty and deletes are always a good option
reaves11
Feb 10, 2013 02:29 PM
mtl0727
Nov 19, 2005 08:14 AM
