Exhaust brake ?
Old Apr 14, 2009 | 09:15 PM
LFD2037's Avatar
Exhaust brake ?
Just got a new '08 & was wondering if you leave the exhaust brake on all the time or just when towing? TIA
Old Apr 15, 2009 | 07:42 AM
txfiremedic's Avatar
Leave on all the time with the exception of wet roads. It'll save your brakes and it's better for your 6.7
Old Apr 15, 2009 | 09:51 AM
Ranhil's Avatar
Interested on why you said not to use it on wet roads?
thanks
Old Apr 15, 2009 | 10:15 AM
On wet slick roads it can cause you to lose control.
Old Apr 15, 2009 | 10:16 AM
LFD2037's Avatar
thanks
It can cause you to slide around & loose traction, @ least it does on a 40K lb. Quint( a type of fire engine).
Old Apr 15, 2009 | 12:29 PM
Ranhil's Avatar
that is interesting. I pull a 32ft gooseneck LQ horse trailer and love using it on poor road conditions. It shuts the whole rig down much better on ice/sloppy roads than the truck and trailer brakes do. Just my 2 cents.
thanks for the info.
Old Apr 15, 2009 | 09:51 PM
Lil Dog's Avatar
They are meaning using it on bad roads empty, no load.
With a 10K trailer on the back thats what its made for.
Old Apr 15, 2009 | 09:54 PM
ChrisM55's Avatar
I used mine all winter on ice and snow with no ill affects. Put in the 4x4 turn the EB on and it just purrs down as I shift down. I leave mine on all the time.
Chris
Old Apr 15, 2009 | 10:04 PM
Navy7797's Avatar
Wondering
I'm wondering why it's better for the 6.7? Does it help blow out/burn up soot?
gordy
Old Apr 15, 2009 | 10:08 PM
Lil Dog's Avatar
Its been reported to help reduce the soot buildup in the sliding nozzle of the turbo. Over time the soot collects on the nozzle ring and it starts to bind. This throws a code eventually and they have to drill the turbo center section for a hole to clean the turbo and plug it.
It seems after time, all the VGT turbos need to be cleaned weather you have the DPF/EGR deletes or not or if you use the EB on a continual basis. This appears to be a service item that will eventually have to be done to every turbo.
Old Apr 16, 2009 | 09:50 AM
coolbreeze's Avatar
I'm thinking my turbo will be ok. I use the EB a lot slowing from 75mph.
Old Apr 16, 2009 | 10:57 AM
Lil Dog's Avatar
I was just on the phone with a good friend that shuttles RV's between the US and Canada. Has about 160ish K miles on his truck and all it does is haul. Uses the EB all the time of course and just recently had to get the turbo "fixed". I would think this would be one not to worry about, but it seems not the case. Oh and this rig also is not emissions friendly, so that doesn't come into play.
rcs7
Sep 30, 2009 12:05 PM
Mopar440_6
Feb 11, 2007 10:50 PM
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
