Edge Juice?'s
Edge Juice?'s
This is on my Dad's truck. It is a 08 4 door 4X4 with 6 speed manual. And 40K miles.
What kind of EGT's should he be seeing empty on levels 4 or 5 and towing on level 2? He is hitting 1500 while towing not for extended periods just on some hills he said. Is that too high or not. I know that on my 04 I will hit 1600 while racing. And alot of folks say to let out at 1400. Is it fine to run at those temps or should I suggest he tow on the stock setting. I think he said he was getting close to 1400 while towing on the stock setting.
Also what kind of MPG increase has everyone notice while empty with this box?
Thanks
Thanks
I just got the edge juice w/ attitude a couple of weeks ago on my 07.5. I have not towed with it yet but while driving empty up a pretty good grade my egt's were1150 but went up to 1350 while in regen. I have not tried power settings 2 - 5 yet as I am experimenting with mileage in level 1 and plan to do the others on down the line. On level 1, I am seeing about a 1 mpg increase. I also added a aFe intake and a MBRP dpf/back exhaust.
When I first put the edge in the egt's where at 1100 or so just normal driving and 1300 or so in regen. Since than I have deleted my DPF and EGR and my temps are below 800 when on the interstate. I have found the best milage is on number 4 but I am on my second Box.
The 6.7's run alot hotter than the 5.9's. I think 1500 is geeting a little warm IMO but I know guys that will run 1500 for several minutes.
MrSuzuki
Aug 25, 2009 07:22 AM
razor6
22
Jan 20, 2006 03:43 PM
ataboy9026
Dec 28, 2005 05:06 PM
djcheez
Oct 15, 2005 04:13 PM
