DPF regen monitored by Edge Insight
I think this will answer your question.
http://www.edgeproducts.com/product.php?pk=81&pvk=248
I'm thinking this might be an afforable way to get data rather than the more traditional route of pillar guages.
Question? This is just a monitor, not a performance enhancer? So, this shouldn't void any warranties?
ben
ben
Isn't much help...
Maybe I'm dense, but I don't think that paragraph on the Edge site is very helpful...
In addition to all of the parameters that can be displayed, diesel owners can purchase a thermocouple probe that connects to an additional sensor port on the OBDII connection and display EGT (Exhaust Gas Temperature). Or the same connection can be used to input a wideband 02 sensor. And for owners of new diesels with diesel particulate filter (DPF) traps, the Insight displays DPF regeneration status.
Does anybody with the Edge get any DPF info without the probe?
The only thing you need the probe for it EGT reading,nothing else. Yes,it also reads Boost without additional wiring.
Only monitors stuff not a performance enhancer,my dealer liked the idea of the running Insight
The Insight is not glitch free,my truck will not display boost,throttle position or engine load correctly with the Cruise Control on,maybe its just because its a Cab & Chassis truck,also the MPG reading is not correct on the Insight. Make sure you update your Insight before plugging it in.
I heard you could loosen the turbo and place a piece of cardboard between the turbo and manifold to catch any shavings from the drilling.
Anyone done that?
I'm less than excited about the Edge Insight. The selections of what you see are criptic. It never did show me what gear I was in...out of the 3 gear selections, 2 say N/A and one says Drive...duh! I know it was in Drive! I was hoping it would say what gear I was actually in! Also, I observed Regen 3 times since I have owned the Insight (temps and lower mileage) and the thing always said Not Run on the Regen Status window. I bought it to monitor the emissions, but now I have an opportunity to get rid of my truck, so I guess I won't be needing it anymore.
Thanks for your reply Ron.
I have another question, if you don't mind...I noticed in your sig that you are running an 5.9 air filter. I have read about doing that, does it make a huge difference? With the price of diesel, I might give it a try to get a little better mpg!!!
As for seeing the regen, im not sure how that insight works, but ways you can tell if your truck is in regen, is if you start seeing higher than 1000 degrees on the #3 exhaust temp sensor. If you also see a thing that says "Delta Pressure", that is reading your pressure on both sides of the DPF. If it is a high number, like 5.0 to 7.0, then you have a pretty good restriction in the DPF, either ash or soot. a number under 2.0 down to 1.0 is better.
Edge insight
I'm very interested in one for my truck as I soon will be pulling 15,000 lb fiver and would like to monotor the truck. Not all that excited about doing another pillar mount job for gauges. Was at dealer yesterday for oil change and talked to service writer about the insight. He claims anything that plugs into OBD MIGHT affect warranty. Says had 2 cases where insight shorted and fried computer.Not sure he really knew for sure as he was one of those guys who always spouts the company line no matter what you ask. Any one know FOR SURE about this.
RattlerSkin
May 1, 2007 04:14 PM
SportTruck
Sep 7, 2005 10:18 PM
kcbarnes
May 4, 2004 11:08 AM
