Diff fluid capacities in manual...
Old Jul 16, 2010 | 03:24 PM
13ALPHA's Avatar
I had to get someone elses opinion. I am looking for the front and rear diff capacities. I know I can find them on the net, and have, but it drove me nuts I could not find them in the owners manual. As a final say in the capacity. The section "Fluids, Lubricants.." seems to only list capacities for oil, coolant. There is a clear page listing types of fluids for t-case, diffs, etc but not capacities.
Am I missing that page or what? Why not print how many pints you need tbuy of the recommended fluid right mext to that?
Old Jul 16, 2010 | 06:26 PM
07 ThunderRoad's Avatar
From the '07 service manual
FLUID CAPACITIES
DESCRIPTION
SPECIFICATION
FUEL TANK
1500 Short Box
98L (26 US Gallons)*
2500/3500 Short Box
128L (34 US Gallons)*
All Long Box
132L (35 US Gallons)*
Cab/Chassis Models (Standard/Rear- Mount)
197L (52 US Gallons)*
Cab/Chassis Models (Optional/Mid-mount)
83L (22 US Gallons)*
ENGINE OIL WITH FILTER
3.7L
4.7L (5.0 Quarts)
4.7L
5.6L (6.0 Quarts)
5.7L
6.6L (7.0 Quarts)
5.9L/6.7L Diesel Engines
11.4L (12.0 Quarts.)
COOLING SYSTEM
3.7L
15.4L (16.2 Quarts)**
4.7L
5.7L
17.7L (18.7 Quarts)**
5.9L Diesel Engine
26.5 (28.22 Quarts)**
6.7L Diesel Engine
21.4L (22.6 Quarts)**
POWER STEERING
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
A/C REFRIGERANT SYSTEM
3.7L/4.7L/5.7L Engines
0.728 kg (1.604 Pounds)
0.850 kg (1.873 Pounds)
AUTOMATIC TRANSMISSION
Service Fill - 42RLE
3.8L (4.0 Quarts)
Overhaul Fill - 42RLE
8.3L (8.7 Quarts)♦
Service Fill - 45RFE/545RFE
4X2 5.2L (5.5 Quarts)
4X4 6.2L (6.5 Quarts)
Overhaul - 45RFE/545RFE
14 -16L (14.8-16.9 Quarts)♦
Service Fill - 48RE
3.8L (4.0 Quarts)
Overhaul - 48RE
14 - 16L (14.8 - 16.9 Quarts) ♦
Service Fill - 68RFE
Overhaul - 68RFE
15.6 - 16.6L (16.4 - 17.5 Quarts)♦
Service Fill - AS68RC
6.8L (7.2 Quarts)
Overhaul - AS68RC
13L (13.74 Quarts)♦
MANUAL TRANSMISSION
Diesel Engines - G56
5.6L (12 Pints)
5.7L Engine - G56
4.7L (10 Pints)
GETRAG 238
2.2L (4.6 Pints)
TRANSFER CASE
NV241 GENII
1.6L (3.4 Pints)
NV243
1.6L (3.4 Pints)
NV244 GENII
1.6L (3.4 Pints)
NV246
1.9L (4.0 Pints)
NV271
1.89L (4.0 Pints)
NV273
1.89L (4.0 Pints)
FRONT AXLE ± .03 L (1 oz)
C205FD
1.6L (56 Ounces)
9 1/4 AA
2.2L (74 Ounces)
9 1/4 AA EL
2.0L (68 Ounces)
REAR AXLE ± .03 L (1 oz)
9 1/4
2.1L (72 Ounces) ***
10 1/2 AA
2.5L (85 Ounces)
10 1/2 AA EL
2.5L (85 Ounces)
11 1/2 AA Open
4.2L (142 Ounces)
11 1/2 AA Trac-Rite
4.0L (135 Ounces)
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
Never use L.S. additive in a Trac-Rite Diesel truck rear axel
♦ Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary. (Refer to 21 - TRANSMISSION/TRANSAXLE/AUTOMATIC - AS68RC/FLUID - STANDARD PROCEDURE) (Refer to 21 - TRANSMISSION and TRANSFER CASE/AUTOMATIC TRANSMISSION 42RLE/FLUID - STANDARD PROCEDURE) (Refer to 21 - TRANSMISSION and TRANSFER CASE/AUTOMATIC TRANSMISSION 45/545RFE/FLUID - STANDARD PROCEDURE) (Refer to 21 - TRANSMISSION and TRANSFER CASE/AUTOMATIC TRANSMISSION 48RE/FLUID - STANDARD PROCEDURE)
Old Jul 16, 2010 | 06:45 PM
13ALPHA's Avatar
Thanks! *print*
So you need a service manual to get those capacities? Crazy.
Dumb questionm, 2500=1.5AAM and 3500=11.5AAM?
My chiltons "axle id" doesn't seem to match. Checked glove box, no sticker. No tags on axles, must have been removed.
Old Jul 16, 2010 | 07:11 PM
The 10.5" and 11.5" AAM axles are used in the 2500 & 3500 trucks. Call the dealer with your vin. They will tell you what axle you have.
Old Jul 30, 2010 | 09:05 AM
thenrie's Avatar
The AAM Limited Slip axles DO NOT require the LS additive. Use 75-90 synthetic oil. My 11.5" rear took approx 3.8 quarts to the fill hole. Apparently the "Trac-Rite" referred to above is the AAM Limited Slip. My spec sheet just indicates "LS" and the VIN indicates the AAM axle. Just for info, 32oz = 1 quart; 135oz = 4.22 qts. I could not get that much into the rear, and I didn't leave the +/- 1/4" from the fill hole the manual indicates. My fill came to about 122oz.
Might also add that the NV5600 standard trans requires 9.5 pints (4.75 qts). 1-2 pints overfill is recommended by many mechanics. Mine took 11.5 pints, including about 2 pints overfill through the top bolt hole on the driver side PTO cover. I used Pennzoil Synchromesh. DO NOT USE regular gear oil!
13
Feb 16, 2012 09:48 PM
I SPEED
Jun 16, 2005 12:08 PM
mestdagh
Jan 10, 2005 11:10 PM
tarpilot
Sep 27, 2003 04:46 PM
bdog
Dec 18, 2002 05:55 PM
