determining Rear end gearing
Old Jul 31, 2008 | 01:45 PM
bstiger's Avatar
I have a 2007.5, 2500 6-speed manual 6.7 liter and curious on how to determine what gear ratio I have in the rear end.
On flat ground at 70 mph, I am @ 2000 rpm with all stock including tires.
Old Jul 31, 2008 | 02:30 PM
gsbrockman's Avatar
3.73:1 as, to the best of my knowledge, 4.10's weren't available with the G56 manual transmission.
Greg
Old Jul 31, 2008 | 03:43 PM
BroncoHound's Avatar
Look on your window sticker. If you can't find it, mark the side of the wheel and the rear driveshaft. Count how many rotations the driveshaft makes for 1 full revolution of the wheel. 3.5 turns=3.42 gears. 3.75 turns=3.73 gears.
Old Jul 31, 2008 | 04:53 PM
WmKRider's Avatar
Rear end ratio
You may want to look at the "Pumpkin".
It usually has a tag that gives the ratio.
Old Aug 2, 2008 | 05:32 AM
Hounddog's Avatar
No tagas on AAM axels.If its not listed on the window and you didn't pay extra for it as a option its 3.73.
Old Aug 2, 2008 | 05:34 AM
Hounddog's Avatar
Hey WMRIDER fill out yiour sig.like the rest of us.Make sure of your replys before shooting from the hip.
Old Aug 3, 2008 | 10:55 PM
Jim Wilson's Avatar
I had an 06 and with the 6sp man and 245/70/17 I was at 60mph at 2000rpm with 3.73. I now have an 07 with the same 6sp and get 63mph at 2000rpm with 235/80/17 and a 3.73 which makes sense because the wheels ar 5% taller. 70mph at 2000rpm doesn't make sense unless they changed the trans or the rear is less than 3.73- I don't think either applies and no stock wheel/tire is going to make that big a difference. I would love 70mph at 2000rpm.
Old Aug 4, 2008 | 06:47 AM
Both are possible changes. The G56 DID undergo a change in the overdrive gear in 07.5 when it was mated with the 6.7L (i think from a .79 to .72, though don't quote me on those exact numbers). Also, though i don't know if it was offered in 07.5 but sure is in 08, 3.42 gears are offered with the G56. At 63 MPH, I am currently at 1600RPM. This is with 35" tires and my speedometer calibrated spot-on, verified by GPS. At 70 MPH I am just a hair over 1800RPM and was around 1950RPM @ 70 MPH with the stock tires.
Old Aug 4, 2008 | 06:18 PM
Jim Wilson's Avatar
Makes perfect sense now that you say they changed 6th gear. I figured I would add my $.02 since I had a manual 06 and now have the same tranny in my 07 with the same gearing. I knew they must have changed the ratios or something else was off. looks like he just has a 3.73 with the new higher 6th.
Garrett5462
Aug 21, 2007 11:42 PM
JD730
Nov 27, 2006 05:54 AM
-Ross-
Jun 19, 2006 09:52 AM
faurotus
Apr 5, 2003 10:49 PM
