DA question
Old Oct 7, 2007 | 03:50 PM
ebenaj's Avatar
DA question
OK this may be a DA question but hers it goes. The wait to start indicator does not come on at all in my truck, is this normal for warmer outside temp? My power stroke would light up all the time regardless of outside temp or length of driving.
Old Oct 7, 2007 | 03:59 PM
sabersix's Avatar
Mine has only come on a few times when the temperature was in the 50s.
Old Oct 7, 2007 | 04:00 PM
txfiremedic's Avatar
Yes its normal, you will only see it stay on when its really cold out.
Old Oct 7, 2007 | 04:04 PM
ebenaj's Avatar
Thanks..........learning curve coming from a powerstroke....
Old Oct 7, 2007 | 04:10 PM
AirGrabber's Avatar
Yes it is normal. It wont come on until 50*. The grid heaters will also cycle until for 60 seconds or until you reach 15mph. For you new guys, when the grid heaters are cycling, they do draw a good bit of current, you will also see a voltage drop, and your lights dim briefly when they it is cycling.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
