Crank Case Re-route
Old May 25, 2008 | 03:54 PM
Cummins610's Avatar
Crank Case Re-route
I think this is a great thing to do.
READ HERE
Old May 26, 2008 | 07:09 PM
Cummins610's Avatar
No comments?, We were worring about the oil from K&N filters with out 5.9L's and the 6.7L get all the blow-by into the turbo
Old May 27, 2008 | 08:28 AM
jkitterman's Avatar
On the 6.7 the vent runs through a filtering system. The filter gets replaced at regular intervals. They way he did it is completely wrong as it is no longer venting. He may end up with crankcase pressure problems. This link will explain the venting but it isn't the exact model used.
http://www.cumminsfiltration.com/pdf...es/LT32549.pdf
Old May 27, 2008 | 12:11 PM
Cummins610's Avatar
Ok,I never recalled about the filter. He did drill holes into the bottle for venting,where is the filter located on the 6.7L?
Old May 27, 2008 | 05:52 PM
GMScott's Avatar
The CCV filter is located under the valve cover. Big filter, looks almost like a tranny filter. I believe the manual calls for it to be serviced around 65k miles. The overhead will tell you when it needs to be done. My overhead gave the message some time after 70k miles though.
wyododge
Aug 18, 2011 07:48 AM
sootnsmoke
Jul 17, 2011 06:31 AM
92smokin blacky
Feb 28, 2011 02:36 PM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
