caster adjustment
Old Jul 25, 2015 | 02:25 PM
killfast11's Avatar
caster adjustment
Hi folks. Have an 03 dodge 3500 4x4 ho with nv5600. Its all stock with the exception of the upgraded steering linkage.
Im at the alignment shop now. Have been having problems with it pulling hard to the right, but darting left when the road crown changes.
Brought the alignment specs from another thread on here to the shop. My caster though will not go down to the 3.2 range. Lowest it will go is in the high 4 range. So what are some things i can check?
Also evertime i bring it back to the alignment shop,4 times in 6 weeks, its out of alignment. Toe in is off each time. The upgraded steering is factory t-type 2009 style only a year old. Could it be wore out that fast.
Old Jul 25, 2015 | 05:36 PM
Danderson's Avatar
You're not running Toyo MT's are you? No moog bj's?
If so an adjustable Fox or similar gas charged steering stabilizer will kill the pull.
Cadillac Man
May 8, 2010 09:52 AM
mstep3
13
Apr 8, 2010 03:23 PM
243
Dec 9, 2004 04:34 PM
xp8103
Nov 8, 2004 10:59 AM
030303
May 28, 2004 11:19 PM
