Can't figure out what gear ratio I have
Old Mar 6, 2008 | 10:18 AM
armourbl's Avatar
Got a new 2007 a couple of weeks ago. It is a 2500 Mega Cab, 2WD, SLT, 6.7.
Looked everywhere and can't find any documentation that shows what gear ratio is in the differential. Looked in the door jams, glove box, dealer invoice, window sticker, on the differential for the metal tag, etc. Still no luck.
I can tell you that on the freeway cruising at 75 mph I'm still below 2,000 RPM on the tach.
Any ideas?
ben
Old Mar 6, 2008 | 10:37 AM
Chad04Ram's Avatar
If you had the 410 option it would be stated on your window sticker as , I believe a 50$ option.The 07's only had two available ratios, the 410's and the 373's .The standard ratio is the 373's. I hope this helps.
Old Mar 6, 2008 | 10:51 AM
Tedonlin150's Avatar
If your below 2000 RPM at 75 you probably have the 3.73 but I can't garantee it.
Old Mar 6, 2008 | 10:54 AM
coolbreeze's Avatar
Well, from a dead stop, can you burn a little rubber or a lot ?
Old Mar 6, 2008 | 11:15 AM
ratlratl's Avatar
MMMmmmm.... Grits!!
Shoot me the VIN by PM and I'll send you an options report.
Chris
Old Mar 6, 2008 | 12:27 PM
Hayseed's Avatar
Auto or manual?? If manual it has 3.42 if auto it has probably 3.73.
Old Mar 6, 2008 | 05:12 PM
armourbl's Avatar
Chris
Very cool. I don't have the VIN on me, but I'll send it to you when I get home.
BTW, it burns rubber just fine, maybe too easily. LOL
ben
Old Mar 6, 2008 | 05:52 PM
GMScott's Avatar
Originally Posted by armourbl
I can tell you that on the freeway cruising at 75 mph I'm still below 2,000 RPM on the tach.ben
An auto trans with 4:10's will still be just under 2k r.p.m.'s @ 75 m.p.h. like 1,950 or so. The 3:70 gears would be a lot lower r.p.m.'s I guess.
Old Mar 6, 2008 | 09:07 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
He has 3.73's.
Chris
Old Mar 6, 2008 | 09:37 PM
Teamropinram85's Avatar
I'm at 2100 @ 70 mph what gears do I have?
Old Mar 7, 2008 | 11:03 AM
bigblock2stroke's Avatar
the only rear gear available for 07.5 with manual trans was 3.73.
Starting in 08 model, you can get manual trans with 3.73 or 3.42.
at 2100 at 70mph with g56 manual trans you have the 3.73's.
wizkid
May 22, 2006 08:43 PM
ramtd02
Mar 26, 2006 12:58 PM
StrokeThis2500
Feb 16, 2006 12:47 PM
dieslcruisrhead
Jan 19, 2005 09:50 AM
slighfoxs3500
Oct 12, 2003 10:42 AM
