Alternator issue?
Old Feb 15, 2007 | 09:05 PM
rundm's Avatar
Alternator issue?
I have a brand new 07 2 wd and was wandering if someone has the same problem I do. When the engine is cold, the voltmeter drops below 14 inside the cab, the lights dim and the engine slows down. Again, this appears to only happen when the engine is not warmed up and I am at idle. Does or has anyone else observed this problem also? Thanks in advance, Rico
Old Feb 15, 2007 | 09:06 PM
rustyshakelford's Avatar
its normal. thats the grid heater going thru its cycle. i believe it stops if you go above 15 mph or it warms up enough
brett
19mike92
Oct 19, 2013 08:32 PM
caper11
Aug 30, 2011 06:53 AM
RCinMesa
Mar 1, 2010 01:33 PM
5.9Excursion
Mar 13, 2008 07:08 AM
Munchies
May 27, 2006 10:30 PM
