2009 3500 Tow Rating
Old Aug 25, 2010 | 06:13 AM
AlCorr's Avatar
The tow rating on a 2009, 3500, 2/wd, Auto, DRW, 3:73, is only 13800lb, On my 2004, 2500, 2/wd, SRW, Auto, 4:10, is 13,450lb. The only reason I was looking for a new truck was I'm looking at a bigger 5th wheeler, What's up with this, a 3/4 ton truck to a 1 ton and I can only tow 350lb more?
http://www.dodge.com/towing/D/vehicl...E+Transmission
http://www.dodge.com/towing/D/vehicl...c+Transmission
Old Aug 25, 2010 | 03:30 PM
mega-engr's Avatar
"California Style"
Its the gearing!
Scotty's Avatar
Top's Younger Twin
Just an educated guess here...the 09 3500 is heavier and Ram is deducting that weight. Gears make a difference too. I know it probably makes no sense to us but its odd how they calculate things.
Old Aug 31, 2010 | 09:17 PM
DodgeChallenger's Avatar
Also the Dodge is the only manual that is rated higher than a slush box auto. Buy a manual if you want to haul more.
Old Sep 1, 2010 | 09:42 AM
sheriffav8r's Avatar
Not true for the 4th gens! I think it all boils down to gearing and the manual is only available in 3.42 and 3.73 with a max tow rating of 14,300 for a SB 4x2 3500 3.73. The auto is available in 3.42, 3.73, and 4.10 and has a max tow rating of 17,000 for a QC 4x4 3500 4.10. These are for '09 models and are a little different for the '10s and '11s (14,100 for the manual and 17,000 for the auto)...
Old Sep 1, 2010 | 03:48 PM
mega-engr's Avatar
"California Style"
Auto vs Manual trans arguements aside, I agree that it is the overall gearing (such as in the axles) that provides the overall tow rating capability. Automatic equiped truck with 4.10 wins over a manual with 3.73...
I imagine that if the Manual was available with the 4.10 then it would be the king though.
Old Sep 1, 2010 | 05:59 PM
AH64ID's Avatar
Yep its all the 4.10 vs 3.73, get 4.10's if you want to tow heavy.
Old Sep 8, 2010 | 04:51 PM
Yahooligan's Avatar
I think the big number that's being overlooked here is GVWR, the 3500 has ~2000lb more payload capacity than the 2500 in the specs linked above. If you're running close to GVWR due to pin weight but are still a bit below GCVWR then a 3500 would give you some breathing room.
Red3quarter
Jun 7, 2009 02:22 AM
Red3quarter
Apr 18, 2009 11:39 PM
jbjarko
Apr 12, 2009 12:01 AM
beardedone
Apr 23, 2008 09:56 AM
