17+ mpg
Old Apr 22, 2007 | 09:59 PM
Steven K's Avatar
17+ mpg
Have close to 600 miles on the new truck. Last tank of fuel was used 75% highway, 25% city, got over 17 mpg. I had my foot in it more than a few times.
Old Apr 22, 2007 | 10:29 PM
runamuk's Avatar
Is that hand calculated or overhead reading?
My best was 20.5 hand calculated and 18.79 while towing only after 20k miles.
Rick
Old Apr 22, 2007 | 11:45 PM
Steven K's Avatar
Hand calculated, but the overhead was very close.
Old Apr 23, 2007 | 12:10 AM
CopeMan's Avatar
How are you getting that kind of mileage on a 6.7? Im only getting13 mpgs. My truck only has 1,500 miles on it though. Will I get better mileage later? Is there anything I can do to get better?
Old Apr 23, 2007 | 09:03 AM
Lurch519's Avatar
What axle gears do you have and what are your RPM's at 75 mph ?
Old Apr 23, 2007 | 09:07 AM
P.J's Avatar
P.J
Yes, and YES!
You are not even close to what most would consider "broken in" yet. I got about 12.5-14 MPG's until I got about 5K on.
Easy on the skinny pedal is the absolute best way to save fuel, no arguments about it.
Old Apr 23, 2007 | 04:00 PM
XLR8R's Avatar
Best thing you can do for great mileage is cruise at the CTD's "sweet spot" RPM (1800-1900) and keep boost as low as possible.
Old Apr 23, 2007 | 04:15 PM
duckbill's Avatar
My overhead, which reads .5 high, was reading 18 mpg at 70 mph from oceanside to sandiego CA (hilly) on sunday after I filled it up. Still at 1400 miles but it was averaging 13.5-13.8 until saturday. I drug the 12k toy hauler up and down some steep hills for 50 miles, under heavy throttle. After I dropped it off, i reset the overhead and saw an immediate jump in milage. I will be dragging the trailer to the east coast in the next couple off weeks which should really speed up break in.
Old Apr 23, 2007 | 04:55 PM
mnmlod's Avatar
I drove 1100 miles back home from the dealership and I got 15 mpg, hand calculated. I was running around 1800 rpm's. I also have 37's and a 6 inch lift. It was all highway.
Old Apr 23, 2007 | 06:18 PM
XLR8R's Avatar
You definitely have better mileage after break-in...
my best so far was Dallas - Houston 19.5 mpg in the '05: 37" Toyos, 9500#s GVW, cruise set for 70mph on the GPS (~ 1925 rpm)... no lift, of course.
Old Apr 24, 2007 | 09:10 AM
GMScott's Avatar
Finally got into double-digits while towing 8k lbs. @ 74 m.p.h. Managed to get a whopping 10.5 m.p.g. hand calced. Overhead was about 1 m.p.g. off showing 11.5 m.p.g.
8,500k miles on the clock, getting stronger, although this truck was VERY strong right from the start compared to the 04.5.
Old Apr 24, 2007 | 11:13 PM
Strjock81's Avatar
Now try and tell me Dodge doesn't calibrate their overhead readouts to reflect a higher milage than actual. I don't think I have seen anyone with a stock truck say "My overhead consistently reads about 1-2 MPG lower than hand calculated."
I know they can do it--I have a Chevy company truck and it is within .1 to .3 MPG when hand calculated. It is so close over so many checks I just go by what it says now.
Old Apr 25, 2007 | 12:15 AM
XLR8R's Avatar
Why do you think DC would purposefully calibrate the overhead readout to artificially inflate the mileage numbers?
Old Apr 30, 2007 | 12:56 PM
Joe T's Avatar
My 1500 hemi was right on by .1 or so when I checked it a couple times.
My Cummins is off by about 10% too high on the first fill up... Mine is a 5.9 though, just thought I'd add that factoid in. Although I'd need to test it a couple times before pointing fingers because it could be variations in pumps.
bngcustoms
45
Jun 20, 2009 06:55 PM
richard
26
Sep 6, 2007 01:35 PM
bigfish5
Sep 19, 2006 12:56 AM
Maddog
Jan 3, 2003 10:01 AM
rshelton88
15
Dec 22, 2002 09:40 PM
