'08 3500 Exhaust Brake Indicator Flashing
Old Sep 16, 2015 | 02:13 PM
rammike's Avatar
Exhaust Brake Indicator Flashing in instrument panel, not the button. Tow/Haul mode, boost is very low, acted like the VGT may have hung up, engine brake not very effective, boost very low, cycled E brake off boost improved but not normal. Shut down to re-fuel and it worked fine for 400 miles? Anyone seen this happen? 2 years and it's a 1st for me.
Old Sep 16, 2015 | 05:20 PM
mega-engr's Avatar
"California Style"
I would take it out for a good hard running with e-brake and tow/haul. Go on the freeway and take off ramps to manually down shift the trans and make the e-brake work real hard and have enough pressure to possibly blow out and clean up turbo. Might be getting ready for a manual turbo cleaning or new one. Hear similar issues like this frequently.
Old Sep 16, 2015 | 05:22 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
A common issue is for the VGT to get soot caked around them so they will not function properly this is why you want to keep the exhaust brake on at all times, keeps them moving and doesn't allow the soot to harden around them.
Sounds like at the very least you need to clean the turbo.
Old Sep 16, 2015 | 07:49 PM
rammike's Avatar
Thanks for all replies. That's what I figured, I do use the E-brake always when towing, which is 98% of the time.
Old Nov 17, 2015 | 03:51 PM
nkennedy's Avatar
When you say "clean the turbo" do you mean to remove it, and dismantle it?
Old Nov 17, 2015 | 05:28 PM
mega-engr's Avatar
"California Style"
I believe there is a process and/or special proceedure to clean the Turbo. It involves a certain solvent and an access port on the turbo. Does not involve a disassemble or rebuild of the turbo.
Old Apr 24, 2016 | 06:32 PM
dozer12216's Avatar
Any progress on EB matter
Old May 24, 2016 | 11:00 AM
rammike's Avatar
It never did it again, after refueling I went on my trip, it's been fine ever since. I do use the EB always unless it's slick out, used to use it when towing.
TxDiesel007
Dec 30, 2010 02:49 PM
mike wolfe
Nov 16, 2009 05:12 PM
belgianmagic
Apr 4, 2007 08:37 PM
TRAILBREAKEER
Dec 27, 2003 05:00 PM
